clarification on vehicle tipper stabilizer trolley
clarification on vehicle tipper stabilizer trolley:
hi excuse me if I disturb, I do not know what you call it, we called it cradle or stabilizer trolley support, I am referring to that device with hinged arms that opened when the body was raised, in modern tippers they are seen only in trucks carrying boulders , I was wondering how you called this system the operating principle strengths defects, why is it almost no longer used when setting up the tipper body of the truck how many variants and configurations are there of this lever mechanism? thanks sorry for the inconvenience
presumably designed to keep the body in line with the chassis and stop twisting and the resultant side loading to what are often long, slender rams AND possible failure/collapse ....... keeps everything in line
The red one is a three way tipper😳 how does the stabiliser work on that one🤔
think it might be a case of .... it might've been once :unsure::giggle: ... but good spot Mog (y)
this wallet device is installed on the bodies of your tippers or is used for heavy duty such as transporting boulders, stones and rocks where the body is particularly stressed, how do you call this hinged device? thank you sorry if I bothered.
