01 zazis 7
F
Fitter steve
I have a 01 zazis 7 track machine not switching off with the key having to stall her to stop. I Generally don’t work at plant. was wondering if anyone had any ideas of areas/ things to look out for or tests to do for this machine
Thanks in advance
Thanks in advance
A little bit of dirt in the stop solenoid seat or a weak spring.
Or if a in line pump, the external stop solenoid spring a bit weak or the linkage stiff or worn.
If you can test for power at the stop solenoid, that will tell you if you have something electrical keeping the engine running or if you have a mechanical fault like @craig suggests
F
Fitter steve
Can’t read engine plate but this is pump plate
