he'd had a JakieB up 'emDon’t think they would have been strong enoughwhen you look at the ramps I’ve ordered
Yes but the front wheels would be near the top before the rear gets on the ramps my telehandler has only got a 2 meter wheel base so all on the ramps at the same timehe'd had a JakieB up 'em
Checked mine today, 3.5 meters long at 1.2meter load height is 20degrees.. wouldn’t really want to be loading up at 30degress!
they are heavy lumps at 55kg each to be swinging around too! But really light considering the weight they carry!!
I don't suppose they were one of his best sellers by any chance?Cheers for the heads up called a few of the companies you guys suggested and all a 4-6 week lead time apart fromso ordered set, 4 meters but with a 6 ton capacity for £1350 delivered +VAT and should be with me by Friday result
Isn’t 30 degrees a shallower slopeChecked mine today, 3.5 meters long at 1.2meter load height is 20degrees.. wouldn’t really want to be loading up at 30degress!
With 0 being flat… and 30 a bigger number than 20 I’d hope not…Isn’t 30 degrees a shallower slope
well when you put it like thatWith 0 being flat… and 30 a bigger number than 20 I’d hope not…![]()
Yeah it’s fine on wheels, nose heavy tracked machines aren’t so nice when they ‘tip’ over onto the ramps. Used to borrow a mates low(bloody high) loader, the ramps must have been 40degrees, horrible thing!!30degrees is fine in a telehandler
Used to load a merlo into a 32t tipper daily on very short ramps. Terrified me the first couple of times but really it wasn't that bad
I bet they are steeper than 20deg. They are designed to work at a particular angle and for max weight carrying its quite steep (could be 30) any less and the weight they carry comes down fairly quick. They will be cut at the right angle to meet the floor at the bottom.Checked mine today, 3.5 meters long at 1.2meter load height is 20degrees.. wouldn’t really want to be loading up at 30degress!
Yep your right it’s 20.051degrees.. I guess my phone app isn’t as accurate as trigonometryI bet they are steeper than 20deg. They are designed to work at a particular angle and for max weight carrying its quite steep (could be 30) any less and the weight they carry comes down fairly quick. They will be cut at the right angle to meet the floor at the bottom.
Edit, swap deg for % which actually makes your 20deg quite steep.
but my trailer is 1.05 meters high so with a 4 meter ramp it won’t be as steep as yours![]()
Just seen this, and was going to suggest ColmCheers for the heads up called a few of the companies you guys suggested and all a 4-6 week lead time apart fromso ordered set, 4 meters but with a 6 ton capacity for £1350 delivered +VAT and should be with me by Friday result
15.218degwell when you put it like that
Just beware if they are not steep enough they won't sit right on the ground and they'll lift at the top when you drive onto the bottom of themwell when you put it like that
That's where proper packers come in. Placed right they don't move, let the labourer do it then you've wasted your time.Just beware if they are not steep enough they won't sit right on the ground and they'll lift at the top when you drive onto the bottom of them
You do know this isn’t the trailer I bought from your matenice ramps Mog .... should've left the ramp hook channel on there
wouldn't it be easier to shorten up the carrier trailer to suit?![]()
