Terext Schaeff HR12 2002 bushes and pins
X
xpuser8334
Hi Guys,
Does anyone know where I can get position 2 bushes and pin/bolt and position 8 and 9 bushes and pins please?
Late HR12 owner..
Thanks in advance.
Diggerdavey
Hi Guys,
Late HR12 owner..
Thanks in advance.
Hi. I have one of those machines and bought all new pins and bushes from kellands. Genuine parts. Not the cheapest but knew they would fit and would be correct for the job
X
xpuser8334
Thank you.. any rough guess on price?? Before I call them tomorrow.
Diggerdavey
I can’t remember off the top of my head as I bought new pins and bushes through out including ram eye bushes. It was 3/4 years back and I seem to think the whole lot was £1000 approx. The last parts I bought I was in contact with Scott Martin there. If he’s still there I’d recommend speaking to him, he was very helpful. At the time I bought several odd parts like fuel filler neck and fuel tank level sender and all were available next day from germany. Goodness knows what covid will have done to that level of service
Hi Guys,
Late HR12 owner..
Thanks in advance.
We can make you some hardened pins to pattern if you send us some measurements
X
xpuser8334
Thanks All - I have the position 2 pins and bushes sorted, but I will probably need to ream position 9 and have inserts made - so I will keep CPS in mind.
thank you :)
X
xpuser8334
Finally all bushes done except two ram eye bushes..
Does anyone know..
On the hydraulic filter housing there is a hydraulic pressure switch
Does anyone know if it is Normally Open or Normally closed?
Light is off when on low revs. But light comes on when at running speed.
Just replaced hydraulic oil with iso 49 and replaced filter with a MANN H7020.
Anyway.. this switch... anyone know please??
Does anyone know..
mine is normally open on the 'Drema .... went U/S last year and had to replace it ... if you've got a new filter in there i'd guess it's foobar-ed
