OOPS
EMYH on Twatter ..........:oops:
it's got a number on it ..... source it elsewhere :rolleyes:
I was thinking it maybe isn't as level where it's sat as it looks and gravity either broke or overwhelmed the slew.
had crossed my mind initially, but looked to be a powered rotation on second look ...... I'd have dumped it and the arm on the bed PDQ ... or at least tried:rolleyes:
Not sure when this was…
Reading the comments, hadn’t allowed for water inside the bridge structure!?
You know it's gone wrong when the Romanian and Irish accents say it's dangerous
I would be questioning why a bridge was built with a cavity that could trap water in the first place??
There also always seems to be a lack of haste to sort things out when they start to go wrong. As soon as it started to tip surely they should start to lower it
I can get Non OEM starter for around £600, or parts to refurbish the one you got without issue for about £100 :ROFLMAO: Something about friends in low places?
box girder structure ... nigh on impossible to make it completely watertight ....... so add some drainage :rolleyes: .... might've been an idea to poke a few holes in the low points first to be sure, eh? :giggle:
That's what I mean
Surely any amount of common sense says when making just about anything like this the holes in the bottom should be more than the holes in the top. Even car chassis have drainage points.
Or use universal beam so that it can be inspected without using ultra sonic measuring equipment
