Battery Chainsaw
Cheapest way to buy genuine makita batteries and charger is to keep an eye out for drill driver and impact driver sets with 2 batteries and a charger. You often find just the batteries and charger add up to more than whole lot.
makita not as good as the dewalt.
dewalt = 54v
Not entirely clear though. Is the Dewalt at 54v not 2ah whereas makita chainsaw with two batteries is 36v and whatever ah batteries you run (i run 5ah). It's swings and roundabouts with all cordless gear tbh and if you've already got one brand and you can utilise the batteries I'd go that route.
That’s just a fact in itself
That's bollocks. All manufacturers excel at certain things and are a bit lacklustre in others.
Milwaukee impact guns knock Makita into a cocked hat.
Makita rebar tier is the best value for money and the only option 'bare' on the market. In fact I think 'Max' brand are the only other brand.
Makita grease gun is better than the Milwaukee ones available in the EU
Metabo mains grinders have the best anti vibe going.
Etc
Yup. Either get the cheap makita and use existing batteries, or spend some coin and then the debate is Dewalt vs Stihl. Otherwise you're comparing apples with oranges.
The twin battery system is a good idea from Makita for juice hungry tools. I've a twin bettery circular saw that's a great bit of kit, it runs the full sized blades so is quite happy with a 254mm metal cutting blade. Very handy.
Russell
What's up with the 181? They are an OK light work saw for the money.
I started it with the discussed technique the other day and was knackered by the time I had it running, it would have used less energy to cut the bit of wood by hand.
Every Stihl I've had has been a sod to start. My 15-20 year old Makita hedge trimmer/strimmer starts first pull after a six month layup.
Hg2702
Hg2702
Etc
I’ve run dewalt for 9 years now and my mates run makita for the same amount of time . We work together everyday and do the same sort of work
I’ve replaced a grinder
he’s replaced everything at least once batteries being the main issue
that’s a fact 👍🏽
this is bollocks
that’s a fact 👍🏽
Maybe he should save some money and use the knockoff batteries, I've had very few problems :ROFLMAO: If batteries were the main issue, why would he replace the tool too??
Cheap tools from each brand are going to be s**t too. I only ever buy the top of the range. Only the best will do- but I afford this by running Bobcats and an LDV :oops:
Pussy :ROFLMAO:
Try a Husky 135 instead. Similar weight etc, a bit cheaper, starts great and has more power. I find mine very comofortable to use.
I just can't stand the outboard clutch!
that’s a fact 👍🏽
this is bollocks
I worked with a joiner who had no end of bother with makita 18v batteries. I've only had 2 14v li ion makita batteries fail but they are from 2006 so i don't think they've done bad the drills they are from are still going strong (modded to take 18v batteries). Careful where you source makita batteries non uk spec are often the ones folk have bother with (joiner i know had loads of them before he found out).
Ive had my eye on the dewalts either smaller 18v one or bigger flexvolts, Ives gone 54v on most stuff inc strimer and hedge cutter for convince but still have big petrol ones as backups
Hg2702
Hg2702
The tools haven’t stood the test of time he’s on his 3rd grinder and circular saw and seems to need a new impact driver each year ! He’s even said he’s change it all to dewalt but it would cost to much
Genuine ones have a chip in them that blocks them after three failed charge attempts, which thoeretically could be due to being very steeply discharged and not being allowed to rest before attempting a charge. This was a large reason for me to go non genuine.
Other manufacturers also have chips in. It's not impossible to believe that genuine batteries from different regions could refuse to play nicely with genuine chargers from other regions?
f**k em all, just use reasonable quality knock offs.
Hg2702
Hg2702
I did see there’s a new battery out. I bought my grandad the 18v strimmer , blower and hedge trimmer as he couldn’t start the petrol ones. Now I dont get a look in if I want to borrow it 🤣
I’d go 54v if I was using it enough or when I used it I was doing something nice with it
The Makita grinders have been faultless (go brushless, I have three) and the twin battery circular saw must be ten years old now and works hard cutting steel. Their impact drivers and wrenches are a weak point- Milwaukee are half the price for the top end ones and if they last longer than a year they'll have beaten Makita!
Like I say, some good and some bad from all manufacturers.
I guess I've just been lucky. But I've yet to replace a Makita battery in a good 5 years or so. And that's been used outside in the wet/cold and mud much of the time. Same battery used for nice dry internal works might have an even better life.
Any one know david Lacey he’s surfacer from Somerset on a lot of the Facebook groups he had a Mikita battery sat on work bench not on charge just sat there, exploded over night and burnt his unit down with wagons and skid steer etc think it was £1.5m insurance claim just from an 18v Mikita battery got it on cctv just exploding in the night
Why do you say Milwaukee impacts are so much better than Mak. Me and a mate have the top end 3/4 " drive of both respective brands. The Milwaukee claims to way outperform the mak but we tried a variety of real life situations and could see any difference in performance and the mak was the cheaper of the two..
I'd love to buy a brushless 18v makita grinder but the old brushed one won't die and i regularly use it part submerged doing drain connections and leave it out in the rain.
