Telehandler
Looking at getting a ‘new’ small telehandler tried a terex 2506 and couldn’t get on with the stupid dead man’s switch on the joystick so looking at a manitou 625 needs to have 6 meter lift but small so I can lift it (at a sensible reach) with my hiab anyone used one🤔
I rate them Paul, twat to work on and very Buggyish but can't fault them tbh, best of the lot of that size in my book.
Good to here, I may have a big set of forks for you to stick on that loading shovel👍
Steady away until I find out if the Scheduling Valve I have on mine can be rebuilt with Tig...... If not she might be getting the winch taken off and parted up :( £1400 + Shipping from the States for a new one..... someone has spilt something caustic on the Ally body in the past and it's eaten the valve in just the wrong spot :cry: If it lives I will be well keen for the forks tho.
Ok educate an old man what the f@@k is a Scheduling Valve🤔
It’s ok just read your other thread😉 its only a block of aluminium with a selection of holes in it, you have all the valves in the old one,
a good machine shop would make you one if you haven’t the time🤔👍👍
For telehandlers without legs it would take alot to beat a Kramer/class
Absolutely fly when you get used to them on bucket work and the lift and breakout force is amazing.
Merlo are not to bad but like marmite
Jcb 536-60 are fast but slightly plasticky interior and jerkier than the Kramer
But probably to big for you . The next
There are no manitous round here that I can think of on farms that run this size machine
Do you want the 6 meters for loading bulkers/ walking floors or for pallet work??
Regy53
Regy53
I like cake
we have a 625 in about to go live
they are stupid money always though .
It’s to do the lifting into first floor buildings with these air con units, the heaviest is less than a ton but the big telehandler I have is way to big, weights nearly 12 tons and is long too, the jobs I do I have to deliver the units and lift them into place and sometimes can’t get my hiab where the lift has to take place so I need to take a telehandler with me and with mine being over 6 meters long takes a fair bit of deck space without the cargo basket and forks plus I can crane a small one onto my short trailer too👍
Yes and no, Holes are oil ways..... Obviously just drilled but at intersecting angles etc.
Might of found a machine being broken tho :love:
These no ‘yes and no’ about it it’s holes in a ally block😂😂 someone made it in the first place
as a great old man said to me once
What man has done, man can do
what never has, maybe
I’ve got an old Merlo 40.7 you can borrow any time mate, not sure what it weighs but definitely a lot less than yours!
Are the jcb 5.6-5.8m machines to small for you.
They are supposedly 6 meter depending on the headstock /pallet forks fitted but run on full size tyres as opposed to industrial tyres
Usually cheaper and more uses than the industrial ones
I agree Paul, issue is as you and I both know is getting others to see the logic.
If I had a Mill, and time, and the tapping tools for the sizes required it'd be a doddle..... it really is a mix of swiss cheese and aluminum. Nothing special but requires the right person with the right aptitude and vision which is a rare and often difficult thing to find.
The pity is the simple reality is it needs to be bang on to work...... God will tig it over the weekend.... If it still fails I'll source a breaker.
I've spent a good half hour today explaining to someone why I want a Grab made to use once......
A merlo🤔 cheers but aren’t they the work of the devil😂 I need to get one on the books then I can weld all sorts of things to it to make my life easier this company seems to be giving me lots of work so need one at the drop of a hat but cheers
and don’t forget if your passing my yard👍
It
it needs to slip into a shipping container too so needs to be narrow and short😳 I have a JCB 520-40 that is ace but lacks the reach, a shame as I only bought it about a year ago so could be up for sale😢
Had a price on a new jcb 525-60 … 50k, for a standard machine with aircon! No aux line at that even!! Safe to say I won’t be getting one!
Kramer seems to be the weapon of choice?
Might be a bit too powerful for you to be fair… (They do have a rep for going on fire and breaking down but mine has been great for the limited use I give it, and it always surprises me what it will lift!).
I haven’t forgotten popping in (I really want to see your shed!), just haven’t been near your parish for what seems like forever!
