Accumulators
Usual process for dumping pressure on 8t Kubota kx080-3a doesn't work any more .... that fancy thing(see photo) I have will force the fittings under pressure but seems to bugger them in short order - I'm guessing the accumulator is faulty (by a bit of research) is that the likely culprit ?
I know I could fit a 't' to dump pressure but what's this accumulator all about and anyone had same issue ?
I know I could fit a 't' to dump pressure but what's this accumulator all about and anyone had same issue ?View attachment 31748
Do they not have a free to tank return?
Accumulator is just a diaphragm that separates oil from water to act as a damper and equalizer so you have a consistent pressure in lines rather than peaks and troughs as the pump is at different stages
what accumulator?
where is it?
what circuit is it in ?
can you not dump pressure by turning off, ign on and activate service to open circuit and drop pressure through the valve block conventionally ??? ....
'praps your servo accumulator ain't working?
do you still have servo pressure with the motor off/ign on, for a couple of actuations?
nitrogen .... water is no more compressible than oil and there shouldn't be any in the system
If you lift boom and turn the machine off. Then turn ignition on, drop the deadman and then try to drop the boom, will it drop?
Well I had never heard of accumulator and don't mind showing my ignorance 🙂
I fancied using my tilt bucket for an upcoming job but it's been such a twat that it's been sent to corner of shed and told not to come back, the usual technique to release the pressure from the system... ign back on - deadman down - button - activate roller has stopped working, so did some research and quite a few posts mention faulty accumulator 🤷
No don't think I do ... hence can't release pressure 🤔
I could understand how a faulty accumulator could cause that.
It's basically a spring putting pressure on the hydraulic system. If the pressure has gone or the diaphragm split there is no spring to hold pressure on the system. Therefore the servo system isn't being fooled into working.
It's worth looking for the accumulator as some are serviceable. Even seen some very old ones with a tyre valve on them for refilling
usually nitrogen filled though
Assume so but never used single acting.
Supposedly on taki you switch off then ignition back on and then switch between aux switches a few times to drop pressure off. It works to a point but i find it a bit hitty missy.
My own method is to leave machine running switch tap over to single acting and then pressure return line (which dumps straight back to tank cos single acting tap is open but also dumps pressure in flow line. V v v rare you can't plug in with minimal effort.
lots of differing styles ... usually bladder type filled with nitrogen to 30-50 bar which will pressurise the servo circuit when the pump is no longer pressurising the circuit and give a couple of actuations, until the pressure in the hydraulic side is exhausted
if the servo circuit won't actuate, the main circuit can't dump it's pressure through the main valve, as it's not being opened by the low pressure servo circuit acting on the main spool.
I like your thinking and will give it a try 👍
View attachment 31749View attachment 31750 View attachment 31751
Must be well hidden if it has one 🙂
servo accumulator on my travel control circuit valve Kev ..... looking at my hyd. schematic it's pre-loaded/filled to 15bar
have another similar one on the dead man's solenoid op. servo valve block, where the servo filter lives ... (not got a pic) and three more in the braking / steering servo circuits :oops:
find your servo circuit's dead man solenoid valve ...accumulator will almost certainly be in the valve block or tee-ed to it on a wander line (follow the dead man switch's cable to it if you can?)
it'll be there somewhere :rolleyes:;)
