Looking at a BR111 for the smaller plant. How do they work, being gasless?
I don't know what size that'll be but takeuchi breakers are rebranded Sandvik/Rammer (mazda if you go back far enough until Sandvik bought them out). I've had one for the micro since it came in 2004 never been any bother and done it's fair share of work.Looking at a BR111 for the smaller plant. How do they work, being gasless?
I like the look of the rammer for lightweight applications. It’s compact too.Just buy one off @Dr pecker sod the rammer
At least there’s no electrics on that Italian built thing of yours![]()
Silenced ones are a bit numb for corners and trench work and I'm not sure longer chisels are available/or a great idea on smaller ones so you're compact reasoning is a good point. Only thing i would say if second hand it needs to be cheap. Breakers are one thing which are either in good nick or fooked and you might not find out right away.I like the look of the rammer for lightweight applications. It’s compact too.
No, new. Want something that would be at home on the E10 and Sherpa, and less numb on the E19 than the current one which fits the E27 much better.Silenced ones are a bit numb for corners and trench work and I'm not sure longer chisels are available/or a great idea on smaller ones so you're compact reasoning is a good point. Only thing i would say if second hand it needs to be cheap. Breakers are one thing which are either in good nick or fooked and you might not find out right away.
I know sharing between sizes is cost efficient especially if they are rarely used but there's a big gap between optimum for a micro and 1.9 ton. I know one is silenced and one isn't but there's a fair difference and that's without getting into flow ratesNo, new. Want something that would be at home on the E10 and Sherpa, and less numb on the E19 than the current one which fits the E27 much better.
Yeah, it was OK to start with but now sharing sizes on the breakers is getting annoying! This will be optimum for micro and 'agile' for 1.9t, I can always use the bigger one on the 1.9t if it's just a straight floor or slab break out.I know sharing between sizes is cost efficient especially if they are rarely used but there's a big gap between optimum for a micro and 1.9 ton. I know one is silenced and one isn't but there's a fair difference and that's without getting into flow rates View attachment 31350
This 80 is spot on tbh. I could be wrong but I have a suspicion it's gasless too although I could be wrong.
@Dr pecker ?This 80 is spot on tbh. I could be wrong but I have a suspicion it's gasless too although I could be wrong.
They are not gasless, they have a diaphragm that wraps around the bodyLooking at a BR111 for the smaller plant. How do they work, being gasless?
No stu, not gasless. Our T80s have a separate accumulator which means you dont have to take the bike pump to it after its been laying around for 6 monthssame here, great tool
Not gasless Rory, she has wind inside mateThis 80 is spot on tbh. I could be wrong but I have a suspicion it's gasless too although I could be wrong.
I have supplied a few T80's for the same model Bobcats (10&19) with a 4 hole bracket to a localish customerYeah, it was OK to start with but now sharing sizes on the breakers is getting annoying! This will be optimum for micro and 'agile' for 1.9t, I can always use the bigger one on the 1.9t if it's just a straight floor or slab break out.
Did you ever get a BR111 @doobin , keen to hear as looking for one for my micro?Looking at a BR111 for the smaller plant. How do they work, being gasless?
