K
keith
wanted truck cab to fit series 2or 3
I really fancy another landy project. I recon a 130 defender with a disco 2 crew cab , auto box, V8 and tipper bed would be a useful tool. Anyone know the maximum allowable mass of a 130 defender?
Just get a decent landcruiser trayback all your wishlist plus it won't break downI really fancy another landy project. I recon a 130 defender with a disco 2 crew cab , auto box, V8 and tipper bed would be a useful tool. Anyone know the maximum allowable mass of a 130 defender?
Just get a decent landcruiser trayback all your wishlist plus it won't break down![]()
seem to recall they did a few 4.5t special spec. ones ... but you'd not be able to drive it on a post '97 licenseI really fancy another landy project. I recon a 130 defender with a disco 2 crew cab , auto box, V8 and tipper bed would be a useful tool. Anyone know the maximum allowable mass of a 130 defender?
Unless you had passed a trailer test before a certain date (i can't remember the date but i know i passed before it).seem to recall they did a few 4.5t special spec. ones ... but you'd not be able to drive it on a post '97 license![]()
think you were still restricted to 3.5t tow barge though GazUnless you had passed a trailer test before a certain date (i can't remember the date but i know i passed before it).
Yeah 3.5 ton vehicle but i thought you were referring to towing capacity over 3.5 ton.think you were still restricted to 3.5t tow barge though Gazor did it give you the 7.5t entitlement ???
no Gaz .... I have a vague memory that they did an ultra-upgrade on some of the 130 Hi-caps to 4.5t gvwYeah 3.5 ton vehicle but i thought you were referring to towing capacity over 3.5 ton.
ha it isnt for me but i did have a series 2a truck cab with a v8 3500s motor shoehorned in it was put in at the right level not like many with front of engine sky high even had front engine driven winch. all a long time ago now though.wanted ..... cheap series two or three ...... to fit @charlie2 's truck cab........ WTF did I ever sell my Mazda turbo powered 110 for (what is now) a pittance
View attachment 30501..View attachment 30502 .. View attachment 30503
SD1 3.5 EFi Vitesse 10.5:1CR flat tops, but 9.75:1 with the big valve heads, with Vitesse headers .. LT77 box and viscous coupled transfer .... went very well on petrol or LPGha it isnt for me but i did have a series 2a truck cab with a v8 3500s motor shoehorned in it was put in at the right level not like many with front of engine sky high even had front engine driven winch. all a long time ago now though.
Man bet that was a faff to get inSD1 3.5 EFi Vitesse 10.5:1CR flat tops, but 9.75:1 with the big valve heads, with Vitesse headers .. LT77 box and viscous coupled transfer .... went very well on petrol or LPG![]()
took some juggling in and a lot of one off plumbing to create something a bit special in a 90"
it took some getting in a mgb v8 oil pump cover with remote filter allowed us to drop the engine flat i also changed the diffs for rover 3.5 coupe 3.9 ratio i used a standard 2a gearbox with fairey overdrive the 3.5s flywheel redrilled for i thing a jaguar pressure plate and standard driven plate. big drum brake conversion as well. it was scary on leaf springs and could be unpredictable, but it could certainly shift and give the boy racers a shock. the v8 90 landy was sedate comparing the two but way more comfortable.SD1 3.5 EFi Vitesse 10.5:1CR flat tops, but 9.75:1 with the big valve heads, with Vitesse headers .. LT77 box and viscous coupled transfer .... went very well on petrol or LPG
Man bet that was a faff to get in![]()
take it by V8S you're talking a P6 not the SD version ?it took some getting in a mgb v8 oil pump cover with remote filter allowed us to drop the engine flat i also changed the diffs for rover 3.5 coupe 3.9 ratio i used a standard 2a gearbox with fairey overdrive the 3.5s flywheel redrilled for i thing a jaguar pressure plate and standard driven plate. big drum brake conversion as well. it was scary on leaf springs and could be unpredictable, but it could certainly shift and give the boy racers a shock. the v8 90 landy was sedate comparing the two but way more comfortable.
a bit more space in a 90s engine bay and you could get a v8 90 very undertuned though the rover v8 was a light engine much less weight than the standard landy motor. when i did mine the 90 was not an option as well out of my price range, mine cost around 650 quid in parts i never kept a record of time spent doing it probably 150/200 hours all told but well worth it, had some fun trialing it but my old 1952 80inch was if anything a bit better off road, good tyres and a less powerfull engine gripped way better i thought.well I did have the entire facilities of my 10,000ft2 fabrication workshop on hand at the time, to make all the special bits, mounts, etc.
... was my 'Sunday' project for a while
... but yeh ... it did take a bit of 'persuasion' ... but was well worth the effort
yes p6 diffs were p5b a lot of people put v8s into series landys but nearly every one was raised at the front to clear the oil filter housing on the mgb v8 a proper british leyland part was used with presure relief valve built in we tried a home made one but could not get it right it blew the remotely mounted filters up or pushed the sealing ring out with inevitable results. i think it cost around 120 quid back in late 80s but it worked properly, i used the overdrive in any gear i wanted to if you had decent oil in gearbox they seemed to me as strong as the rest of the gearbox halfshafts were prone to snapping mainly the longer one but were easy enough to change if you knew how to get the broken bit out of the diff. if it dropped into diff housing diff had to come out but still not to bad a job. the p6 3.5s was very rare i was lucky to buy a breaker that had blown the gearbox for scrap money the only other thing that needed changing for a little extra space was a v8 p5b exhaust manifold to clear the landys chassis, a few people beat the chassis in or cut and welded a scallop in chassis but with the right manifold it cleared the chassis part of the bulkhead needed cutting back and a new section welded in for a tidy job, i saw some right lash ups done and wanted to avoid that, my mate fabricated and machined lots of bits for me on a barter basis i dug foundations and built his garage up to floor level including a pit. and any stuff i needed he done for me. it was a handy exchange for both of us. sadly he had a cancer and passed away at 54 years old. and four years later his brother the same. took some getting my head around that tbh.take it by V8S you're talking a P6 not the SD version ?
the Vitesse flywheel and clutch are as big as'll fit ... pressure is the same diameter as the flywheel and that's a good chunk of metal too ... plus the Vitesse has heavier duty springs and can get the comp. sintered friction easy for the Vitesses, which slips straight onto the LT77 first motion shaft .. just have to swap the spigot for a bigger nosed version ... the power steering box allows a std oil pump, but need to use a shorter body filter with the oil cooler plumbing sandwiched between the pump and the filter top, to avoid fouling the drop arm/drag link. one off engine mounts put the crank nose in the right place, but had to move the chassis mount points forward an inch or so, IIRC
it was possible to get an O/d unit for the LT77 but at £2.5k and rare as hen's teeth S/hand, it didn't get one .... all my RRs with the LT95 boxes in had the Fairey O/d units .. 16fwd./4rev. cogs were real handy ... Fairey said use 3 & 4 only, but i never had an issue in all cogs - ever
was a toss up whether to shoehorn an LT95 into the 90, with an O/d on the back, but needs a fair old tunnel trim/re-juggle and there ain't a lot of room for the clutch pedal in there, in std/LT77 form ........ and the handbrake is a total PITA to locate, if you do.
Sundays were 'fun-days'![]()
thats an early 90 isnt it as later ones did not have vents below windscreen i may be wrong though. i went to eastnor castle when they launched i think the 110. and 90 may of been a bit later think it was 1988 or thereabouts. think it was a 110 county station wagon that first appeared over the hill, i had seen pictures but that was first time actually seeing one for real. i went in my landy it was standard then just a two and a quarter petrol swb truck cab shortly before it had the transplant.SD1 3.5 EFi Vitesse 10.5:1CR flat tops, but 9.75:1 with the big valve heads, with Vitesse headers .. LT77 box and viscous coupled transfer .... went very well on petrol or LPG
