Maxus
So I've just picked up this old yamaguchi tracked dumper and it has a kubota oc62 engine. It's was a real pig to get started so I charged the battery overnight and today disassembled and cleaned up the starter motor. It's helped a lot, as did changing the oil!
The first question I have relates generally to small dieseI engine and is: what else can I do to improve the running of the engine? I don't think it's been properly serviced judging by the state of the old oil.
Second question is a bit more convoluted and relates to the difference between the kubota oc 60 and the kubota oc 62. From what I can gather the main difference is the position of the output shaft.
Currently I have the oc 62:
Here is oc 60:
My question is: What are the chances I can use parts of the oc62 currently installed on the machine to adapt the oc60? I can get an new oc60 much cheaper than an oc62 and it'd be nice to have a brand spanking new engine plus the old one, which works if I ever needed parts, especially as a genuine glow plug is £80 and a genuine starter is £414!!
Here is oc 60:
