mart1602
dont know how i got pedros quote in it but i got a pic on!!
Fecking highWow! How high is that?
Fecking high
Had 4 sets of burning pipes connected together (20 meters each) so about 75 meters in a mesh floored man basket swing in the breeze trying to clean cut galvanised angle iron![]()
Was asked if I could drop it in one, which I could of doneMoved on from the Stihl saw notch in the leg and run days then mate![]()
I’m hung from the crane with the fly jib onhow the hell you sling it ?Looks like the basket M/c doesn't have as much stick as the lift M/c?
... or is that just a trick of the camera angle ?
Heights never bother me .... landing from one would though![]()
I'd sussed that Mog ..... but doesn't look like the M/c you're on had enough height to get you up to sling t'other m/c's chains to the lift point aboveI’m hung from the crane with the fly jib onbut it dose look like the other way around
I see but I can assure you I made it to the topI'd sussed that Mog ..... but doesn't look like the M/c you're on had enough height to get you up to sling t'other m/c's chains to the lift point above![]()
is that first one Trefyl Quarry Angus? ..... going back a bit if it isSouh Wales .
is that first one Trefyl Quarry Angus? ..... going back a bit if it is.... other above Glyn Neath ?? third one looks real familiar , but'd have to be going back a long way if it's where I think it is ??
Maesgwyn , I think. 1965ish
and a better day than we've had, weather-wiseGood views today![]()
