One for druid
diggerjones
diggerjones
As your fountain of all knowledge Graham. How do i stop my water butt leaking. Or anyone else got any ideas!
Maybe knock the middle bands off then heat them up and knock them back on while still hot when they cool should pull it tighter
or try to knock them towards the middle
Has middle band come off?🤔
Try a ratchet strap then do as above?
Oh and give the patio a pressure wash 🙂
diggerjones
diggerjones
Not suremessing with metal straps will do any good. Might try a ratchet strap to see what happens. Or like doobin says and some sikaflex etc
did wonder about what looks like a band that's given up the ghost? ... re-join it and knock it down some?
(y)(y)
or make a band up that is a little shorter with some blocks on the ends which you can pull together with a suitably HT bolt to tighten the band (and barrel segments) up on the centre 'waist' of the barrel (bit like a truck fuel tank band/big pipe clamp);)
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
think a ratchet strap'll stretch too much Dyl
You might think emptying it is a pi** take but if you empty it put it somewhere to dry out and then try tightening bands when you refill it and the wood swells up it might seal. You might also find by emptying it out and getting a look in it its fooked 🙊
diggerjones
diggerjones
Yeah thats the way to go. I've had it 20+ years and been a water butt for 10 years
diggerjones
diggerjones
It was there before i built the building with a little helper thats 11 now
