Neuson engine mount shattered
A
Anygmatic
Afternoon folks,
Wacker Neuson 1t Hi Lift 1001 with Yanmar engine. One of the engine mounts is shattered, causing the engine to drop slightly and now the cooling fan makes a right racket!
I can't seem to locate them online (for once, a well-known search engine hasn't helped...). Pictures attached show one side (intact) and the other (busted).
Anyone able to point me in the direction of a link or somewhere I can get replacements, and any tips (do's and don't's) on the job itself?
Cheers.
A
Anygmatic
Thanks, I will try that but there don't seem to be too many dealers round this area. I was hoping to find a part online somewhere...
But if that fails, I will go to a dealer.
Can you weld it and gusset it? They’re only mild steel.
sorry, just had a better look at the picture. It’s the rubber that’s gone. Try RSonline, you might get lucky.
A
Anygmatic
Yup, it's the rubber. RS - hadn't thought of that - I'll give it a go.
A
Anygmatic
Thanks - looks promising. Will check out the dimensions tomorrow to make sure it will fit but could work.
A
Anygmatic
That's true, and I might even be able to re-use the old plate and just replace the rubber with something similar to the above.
Might be a little while before I get round to it - the dumper is in heavy use atm and I don't want to take it out of action! Cooling fan sounds noisy, but not doing any long term damage (I hope...).
er ... would not want to bet on that ....... sooner or later yon blades are gonna carve a hole in the rad core :oops:
If it's a plastic fan, chances are that one blade will shear, take the rest out plus your rad core. Happened here a few times in the past.
