OOPS
L
Lynchy
Hs2 Copthal end July,big cut dug out top of tbm portal,wagons been in n out for weeks,then one goes over edge
a regular spot just outside of abergavenny, coming in off the A40 ..... it even looks low as you approach it :rolleyes:
Rob65
can't believe 'the Mog' is actually saying something like this :oops::oops::(
If Mog is pensioning this off there can only be one reason - the scrap pile has spawned a successor which needs less work to make it serviceable.
Also there is no need to fear about waste, I’m sure the engine off the old mower will go in to ‘stock’ for a future use now that it is ‘run in’ and proven to be reliable.
Well funny you should say that🤔 going to use the axle (hydrostatic drive) to power a floor saw that needs a “new” engine (borrowed it to a mate who siezed it up😡 got a 2 cylinder diesel for it 👍
