Are any of you clued up on an auto box fitted to a daf 10t. It's a 2004 and is the old stick type selector not the newer twist button....any way my question is are they a good box?
Ive got a zf in my 18t daf. I just wasn't sure on the auto side of things. I've driven the newer auto dafs but not the older ones if there's any difference between them that isThey won't be a daf gearbox.
I think daf use zf gearboxes.
A mate on heavy recovery says despite all the snobbery he sees less dafs than anything else.
At that age and weight it could be a `proper` automatic rather than a automated manual.Are any of you clued up on an auto box fitted to a daf 10t. It's a 2004 and is the old stick type selector not the newer twist button....any way my question is are they a good box?
What makes you think that?From memory - Run Away!
I'm told by the owner its the same as fitted to Leyland buses.At that age and weight it could be a `proper` automatic rather than a automated manual.
It will most likely have a cooling pack for it at the back of the cab then.I'm told by the owner its the same as fitted to Leyland buses.
So is everything I ownWill be a thirsty little fooker then with a torque converter![]()
I'm told bus box not bin wagon.I thought the daf dust carts had hydrostatic transmissions rather than automatic.
If it is the hydrostatic ones then yes I have heard some truly horrific stories of those.
Will be an easy drive for sureWell on test all is well. It is an allison gearbox.
Research hasn't come up with much info on the gearbox so I'll leave my brain to sleep on the outcome if we go for it or not.
How old is the Iveco dropside?Well looks like a deal is done on it. Was one of the tidier trucks I've seen and with it been 10t over the usual 7.5t offerings should fit in to my plans nicely.
So in a few weeks I'll have a tidy sprinter tipper for sale and a 3.0l iveco dropsider.
It's an 06, last of the gen3 shape, it's done around 81k, bloody good truck. It's as good to drive as my 2020 iveco.How old is the Iveco dropside?
