Avant 755i, thoughts on hiring out
Has anyone used an Avant at all, preferably 1 of the bigger models?
If so what was your experience like with them?
I wonder how they would perform in uk wet conditions too.
Your thoughts welcome!
There’s a tracked one about looks pretty good
Yes they look pretty good in the wet. Not too much on the net about them and not many advertised in the UK.
I think the track can possibly be retrofitted
Grahams
Grahams
The tracked conversions are all done by Moorend Ltd, whichever make loader you have. My understanding is the can be fitted or removed as required and are all effectively retrofitted. Not sure if they will deal direct over converting an Avant or whether you have to go through Avant.
Had a rough quote for the tracks yesterday 16 to 17 big ones 😬
Grahams
Grahams
They certainly aren’t cheap, but if you really need them and the job can cover it certainly the way to go. I compromised by fitting the widest turf tyres you can buy. Real Carlos Fandango style, but are fantastic for not marking wet grass and very good on soft sand.
for them as ain't old enough ;)
Mate sent me this was on local film set for new game of thrones prequel
Avant etc are OK in wet, wider tyres the better. You can't expect them to keep running in the shittest conditions though, just as you can't expect a wheeled dumper to keep running.
You'd need some seriously specialist work to warrant those tracks. So much to break on them, and I bet they give a hard ride. There was one on eBay not long back with not many hours, so I reckon they're nowhere near as cool to own as people think they look!
If the ground is that bad that you need tracks, do you really want to be carrying pallets across it? Use a tracked dumper instead. Same goes for moving muck. A digger with auger/postknocker/whatever will be much more efficient in the slop as you can position the tool with the arm.
So what good actually is a tracked Avant?
Seeing pictures on social media they seem to have there place in the snow.
But if the grounds soft enough to warrant tracks I can't see wanting to lift much as surely you would have stability issues.
Also the advantage of a pivot steer is being able to turn the wheel whilst stationary to move the forks. That surely wouldn't do a set of tracks much good.
Surely cheaper and easier to fit duals which is tried and tested by farmer on full size loading shovels so must be up to a fair bit of abuse and nice and easy to swap out
Our towing laws are a pain in the arse, tracked loader would be my preference but can't find 1 with high flow that's towable
Don't know the price but I think all posi tracks are high flow, this is the biggest towable one I think
But they do some really little ones
Or I know no one really wants to operate standing up but would the biggest ditch witch be nearing what you want??
800kg operating capacity and over 2t tipping capacity so not quite as good as an avant but getting there.
