Just about to order LM146.can't decide on Tri Axle or twin...any thoughts?
Twin has more payload. Triaxle goes through tyres at a rate of knots too. Plus more expensive.Just about to order LM146.can't decide on Tri Axle or twin...any thoughts?
You can run the smallest wheels on twin axles too and still achieve the load rating.I personally prefer twin axle but was asking someone with a triaxle Graham Edward why he choose his trailer, he said it had a lower centre of gravity & was easier to load being lower.
these ??If you constantly run heavy/overloaded then get a tri-axle, otherwise save your dosh.
If super-low bed height isn’t critical see if you can order the heavy duty Savero 185 tyres (I think they are on a 13 inch rim) - they have an all-terrain tread pattern and are significantly more resilient than the other Ifor options IME.
They’re the badgers - optional factory fit from IWT on a lot of new trailers and well worth the slight extra cost IMO.these ??
2 x 185/70 R13C GT Savero 106/104N Trailer/ Caravan 185 70 13- TWO TYRES | eBay UK
Kilnhurst Tyres & Exhausts Ltd. Plus budget tyres & many more!www.ebay.co.uk
not for running round they don't ..... tri-axle is better bet for long distance carrying --- smoother ride and less stress on the tyrestwin all the time, tri makes no sense at all!!
I used to think that but having installed air suspension on my Ranger and started towing with the beefier Iveco Daily, the smooth ride is not an issue. I still maintain that a triaxle will eat tyres quicker on anything other than pure motorway miles. It’s any kind of manoeuvres that do it- you can see the tyres squirm and the rubber they leave behind is plain to see too!not for running round they don't ..... tri-axle is better bet for long distance carrying --- smoother ride and less stress on the tyres
Yup, that'd be fair to say- if adjusted correctly. But boy oh boy do you notice the tyre wear!Would there be argument that the 3rd axle whilst increased tyre wear saves other wear in the form of better braking? Braking spread between 3 axles rather than 2- less overheating on long downhills etc. I’ve always had twin myself as find it fine and always want that little extra payload!
One of the biggest culprits for tyre wear is the fact the tri axles tend to use lower profile tyres which don't have the sidewall flex for turning. Tbh if you're carrying a load which doesn't move around (ie not livestock) there's nowt wrong with a correctly loaded twin axle higher centre of gravity or not.Yup, that'd be fair to say- if adjusted correctly. But boy oh boy do you notice the tyre wear!
