Carter Diggers
Status
Not open for further replies.
G
Get Carter
Hi,
The following is the a true description of the no end of problems I have with a CT08 digger. I would advise anyone considering buying one of these please read this or message me.
I'm not the only one though. Businesses who have bought these machines, certainly the CT08 have got rid. They have all said the same thing they hire the machine out and were waiting for the calls. My machine went out 5 days last week. I had to attend 3 times to fix.
These machines are poorly designed and use cheap materials. Metal I can only describe as plasticine..
Long list of issues include, electrical faults, flat batteries, starter motors failing, Hour meters is a constant failing. I have now come across a major issue that will affect all the CT08's and most likely other machine. The tracks will not stay on. Doesn't matter how many times they are pumped up with grease. After a few days they will be hanging.
I have now found out why the piece of plate at the end of the ram opposite to the idler wheel is like a cross shape. Its only welded on onside. The side the force is applied there is no weld. When force/pressure is applied this plate bends that is a mere 7mm thick bends back towards the idler wheel which loosens the track and off it pops.
These machines are not bullet proof they are cheap Chinese crap.
I would now advise anyone looking at buying a machine. Think twice about anything that has come from China. It is buyer beware.
A fool and his money are soon parted. I am that fool.
You do know how to kick a fella when he’s down….
I just can't pass up a opportunity to promote properly made British engineering..... See Face Shovels.
Hi,
Nuff said 👏
The only glimmer of hope I can give you is that I've seen those generic Chinky micros with the single cylinder engine go for silly money on eBay recently. If it's presented right you might get lucky. f**k all stock out there so people are desperate.
I wouldn't swap my E10 for ten of them, personally. :ROFLMAO:
How long have you had the machine?
I was expecting this to be a sales thread about how amazing they are and how they’re just as good as regular brands 🙄
Sorry to hear you’re having problems, has the importer been any use?
Regy53
Regy53
I like cake
Sad to read this. I have always tried to remain impartial to some things but a customer called the other day for a used wacker micro and out us up against one of these 6 k micros. A mans money is a mans money . Waste is wisely
Danny
Danny
You can over tighten a mini digger track it should be a bit slack but still doesnt help with the rest
There are other quotes you could insert here that would be equally valid 😉🤷‍♂️
Status
