Hg2702
Looking for to get a decent second hand scanner if anybody knows where a good place to look for one
Local to you and me is one pointLooking for to get a decent second hand scanner if anybody knows where a good place to look for one
Speak to Lee at One Point.... Star he is.Looking for to get a decent second hand scanner if anybody knows where a good place to look for one
Could be worse.... I have ze same issue.....Mondays expensive phone call sorted![]()
Sorry to have cut you off earlier there was a high level of stupidity that needed beating out of someoneCould be worse.... I have ze same issue.....
a video of it working would be marvellous,did not @Shovelhands make one of those for lime ?Make sure you get cat and genny. Without genny cat is about 25% as useful. Speaking of expensive mondays i had one last week bit of time between jobs/weather and so got round to buying something I've been gonna since last year. Turned up yesterdayView attachment 25744
I've only had it on to make sure it works so far but I should have a fair bit to screen this month for a job. Just hope weather stays as is, its lovely and dry for screening at the mo.a video of it working would be marvellous,did not @Shovelhands make one of those for lime ?
he did indeed ...a video of it working would be marvellous,did not @Shovelhands make one of those for lime ?
Lee is the rep +44 7809 202157Survey Equipment - Laser Levels, Total Stations, Pipe Laser & more...
Laser levels, site levels, total stations and much more. One Point Survey Equipment sell, hire & repair survey equipment from the worlds leading manufacturers.www.onepointsurvey.com
simple answer ... don't work for them ... the b'stards never want to pay you anywayI don't know if you would ever use it on sites run by the big players but it's now 4+ only for cat and genie
And they can be picky about some of the less known brands
Cat manufacturers/sellers will try and tell you that there is all kinds of high tech stuff going on inside and all kinds of witchcraft. Reality is they are a pretty basic tool and i was told by one company that the tech inside is pretty much as good as its gonna get. The only advances made in the last 10 years is gps. This is where the big companies catch people out, with gps and data logging they know of you used it and where.
