Does anyone happen to know or know where to find the RAL code for Kubota dark blue KX-3 series ? local firm going to mix me up a pot but they need code or a lump of the machine to match it against
Cheers
Cheers
Consruction colours should be able to help.
.................... just wanted to tidy the bit that gets kicked when you get in the cab no matter how careful you try to be .
Have you considered using a piece of sticky back "non slip" matting like the OEM's use on the steps. Ollie gave me a few bits he had several years ago. It still wears through, especially if your a rough arse bugger like me but its far easier to change than spraying, imho.
It was already a bit scratched up before I kicked it for 3 years so wanted a bit of paint - I looked for some 3M type tape but couldn't find any - now its tidy would be a good to add something - not familiar with that stuff but will check it outHave you considered using a piece of sticky back "non slip" matting like the OEM's use on the steps. Ollie gave me a few bits he had several years ago. It still wears through, especially if your a rough arse bugger like me but its far easier to change than spraying, imho.
try a boat chandlers Kevin ..... it's used a lot on decks on boats and can usually be gotten in larger bits from places like thatIt was already a bit scratched up before I kicked it for 3 years so wanted a bit of paint - I looked for some 3M type tape but couldn't find any - now its tidy would be a good to add something - not familiar with that stuff but will check it outcheers
