E10 loading dumper?
Russell
Can you load a 1 ton dumper with a E10?
Ive got a job with a long garden and can't face using the tracked jcb dumpster again.
Yes, although it can be a little tight with the whites quick hitch on but it is do able and that's without having to crush material between bucket and dipper.
If you can sit in a bit of spoil but off the deck is fine,
Best dumpers for Micro diggers if your not on the soft are the old 1t 2wd rigid FTD's with a petter single cly pop pop.
Yes,I've put material over a 6ft fence with the e10 before today
Danny
Danny
I can load a 3t swivel with tb210r just tip the skip up on the dumper (y)
Russell
Can you load a 2 ton dumper with a E10? I got on ok with the one ton but looking at the specs the 2 ton is about 200mm higher.
I like the idea of a 2 ton because they do a swivel high tip.
Ollie has a 1.5t swivel high tip, no idea on height.
Would have thought no chance off the deck with the E10 and hitch on
Russell
Yeah I just watched his video. Unfortunately I don't think they do a high tip swivel in the 1.5t.
One I had on hire, specifically needed a high tip.
The lane we where working on wasn't wide enough to get a tipper, or even a 3.5t tipper up, so used the dumper to carry down to a 7.5t tipper waiting at the bottom, and tip into him.
I must admit the high regard a lot of people have for the e10/dx10 would deffo tempt me to look at one if i were changing my micro. But this loading height issue that keeps being discussed puts me right off. Ok i don't have quick hitch on it (i don't think necessary on a micro when weighed up against drawbacks) but i can load a 3ton dumper with tb108.
Russell
It's about time someone brought out a 1.5t, 700mm wide micro.
I was thinking a loader would be useful with the multi purpose ability but anything that can move a ton is £40,000-£45,000. A new 1 ton high tip dumper is £16,000+ vat and I think made in UK and probably a lot better at moving dirt.
What are second hand, high tip 1 ton dumpers like reliability wise? I really liked the one I hired, nice quiet diesel engine and twice the capacity of my tracked dumper. Also no mess from turning on hard ground.
