Justme
Any vehicle fitted with a bar after 2014 MUST have a proper direct clip attachment point.Amazing how many tow bars don't provide anywhere to attach it
With the new style clips you clip direct to the loop not pass the clip through the loop.Yeah and the loop is aften slightly to big etc fir the snap hook so u need a shackle...pet peeve![]()
I bet they do have a clip point its just further under the car than you would expect.Not talking about hooking it over the ball although vw seem to leave little option
If & only if there is no official point or better place you can then loop the ball as a last resort.it's illegal to loop it around the ball ..... must have a separate attachment point
The MOT checks them.Yes it need to be on somewhere not attached to the towball incase the towball comes undone bit I've never seen how that works with a bolted on frame noones checking the bolts to the chassis but you would notice if the ball was loose.
There's so many times when the hole is to thick for the clip but the holes too small for feed the clip through
Most hitches have a wear indicator built in.Anyone ever check for ball wear?
Mate of mine lost a 16ft flat on the M1 with load of unistrut ...ended up sideways on the central reservation... subsequent enquiry etc found the ball and hitch to be worn..jumped out. Newish transit and well maintained trailer. Said it was scariest moment of his life watching it unhitch out his rearview mirror...no one hit it either.![]()
Had it happen to me tracking my 18t off an artic drive forgot to set trailer brakes on managed to track back on backwards to put weight back on the unit axles while driver rushed to pull brake lever on trailer took a few moments to stop once he did unit partly jack knifedJust shows you should set the trailer handbrake when loading especially on a flatbed I had one take off on me luckily I kept going and the pickup wheels came back down and it stopped
that must've hurtThe guy on the wacker below was good
Dunno, looks like a soft wet landing judging by what comes out of his wellies!!!that must've hurt![]()
I felt a bit of a dick recording after reading the comments here about that forklift on site so had to take a bit of a look at myself.
