Licence to drive telehandler on highway
F
fred
anyone know what age and licence is needed to drive telehandler on the road ? We have the apprentice (16) insured for site no problem but am curious what is needed for the road. No doubt when his course starts we will find out but wondered if anyone knew.
Not that we will be letting him loose with 60k of telehander on the road anytime soon....
It's done by weight to a certain extent so will depend on machine but think most are 18
interesting .... used to have to be 21+
I think there are weight restrictions on cat b licence related to age. Up to 3.5 ton at 17. 3.5 to 7.5 at 18 and over 7.5 ton 21. Most construction handlers will probably be in the over 7.5 ton class
Cat B license... 18 up to 7.5t, 21 over 7.5t..... unless a holder of a HGV class 2 (Cat C) in which case age becomes irrelephent.
C
Charlie17
From what I have found it all depends on what the specific telehandler is registered as. For example it could be registered as agricultural plant or a tractor, which from memory has age-related weight limits, however it can all be done on a standard B car licence. There are other categories that it could be registered as a mobile crane which then would mean you would need to have other categories on your licence (C).
However, it's worth bearing in mind that depending on what the telehandler is registered as there could be certain conditions that need to be complied with. Agricultural registration would limit the road activities to those solely for agricultural or forestry purposes and there would also be distance limits that you can't exceed.
It is a complete minefield, I'm not an expert at all, just many hours of reading and trying to better understand the regulations. Best to speak to DVSA (I believe) if you need to clarify certain technicalities - that being said you would need to speak to somebody there that properly understands it.
