Rocky Horror
Has anyone any advice on tensioning the rubber tracks on the 8014? The assembly is as per picture with the 30mm nut. The right hand track has slackened slightly. Should I tighten or loosen the nut, and is there anything else I need to take into consideration? I've already had a go at adjusting, but turning the nut either way doesn't seem to be having any effect on the tension. What is the purpose of the pin on the nut?
