Geith 1200 tilt grader
Had this off Callum originally for my kx71/3 but was too heavy so mtk modified it for kx161-3 used 10 times max, now have tilt hitch so don’t need this anymore.
cutting edge like new no dinks etc and reversible to a unused side
1200mm wide
what’s it worth?
I have one on order from BMC for a KX71 (if it ever the brexit gets here) Scandi style 1100mm 145kg ... hope its not too fecking heavy too :unsure:
anyhow judging what I paid for mine you should end up with a tilt hitch for next to nothing :) must be worth £600
Diggerdave
Just wondering if it would fit on my zx50, it has a 3cx hitch fitted . Tried on Google but can't find dimensions of kx161.
Diggerdave
Thanks for checking, but I think the pin centres are further apart on 3cx, from Google. I won't be able to check my machine till later in the week as it is away on a job.
Off the top of my head 13.5" /343mm c-c, and 6.5"/165mm width.
It’s an easy fix to put the correct pick up on.
Mark
Mark
I’m sure I have one in the yard that would fit a 3c Dave. We had it on a doosan 55w duck, will have a look tomorrow and let you know.
