K
Keif
Right now I've made it so the post cap slides but I could easily switch it at this point. Going to hammer some posts today will definitely try it with a fixed post plate also. Thanks for the advice. Do you use a dangling plumb chain?Glad you got it sorted- you’ll wonder how you managed without it. Are you making it so that you can press down on the post with the post cap like the vector one? I’ve been running knockers in different guises off diggers for 11 years and in my experimenting find the ones without the leg are the easiest to use as it works like the vector one so the digger boom doesn’t bounce every time the weight goes up.
