Just seen this one on Facebook
My pennies worth is this,
The tractor is on Irish plates so they can do what the hell they want
Mog is right the angle iron suggests the trailer is dedicated to the machine or machines and Graham is right, the cutouts suggest the last 2 axles are in my opinion Trackers not steerers. the way its loaded the front 3 axles will be fixed but the weight is more on them so the 2 trackers will be taking weight but not as much, I would expect with a trailer that size and build to have all 5 axles braked. its got a fair size fuel tank against the head board putting weight on the pin so it could spend a fair bit of time spent away from base, the drawbar pull on the tractor is a lot but look where the machine is sat its the trailer taking the weight not the tractor.
If your ballasted with an 8 row, it will regardless snake as you go up the road as you put more axles on the easier it gets a 12 row while being 6 metres longer is a much more stable trailer. I would imagine that behind that tractor at sensible speeds that would tow lovely.
aye ----- dittoThere's no forestry roads round here I'd wanna take that down! Sooner spend half the day tracking it!
for a dedicated set up, like that, it'd be a must have Gra ... loading that'd be fun anywayThe angle iron guides look good. Much safer in the snow or covered in mud.
Graham
