diggerjones
Got this today. Seems a handy bit of kit.
Me too . I’ve got some pads to dig with the mini and I think the ripper would burst through the frosted ground on topI've only had quick hitches 12 months, so having more attachments is the way foward. It used to be painful changing buckets, also the 2 minis i have, have same buckets. Ripper tooth next on the list.![]()
Worth drilling a hole in the bottom of the skip if you get charged by weight . Just to let the rain water out . I found out this the hard way . wondering why my rubbish was getting dearer when it was wet !Bought one recently for my kx, brilliant thing - only used it so far to empty a skip into one next to it (skip firm had been charging for 12 yarders but delivering 10‘S so I sent it back empty![]()
Thankfully I don’t get charged by weight. Had an 8 yarder weigh in with 9.8 tonne last week.Worth drilling a hole in the bottom of the skip if you get charged by weight . Just to let the rain water out . I found out this the hard way . wondering why my rubbish was getting dearer when it was wet !
Where from I’m after one currentlyBought one recently for my kx, brilliant thing - only used it so far to empty a skip into one next to it (skip firm had been charging for 12 yarders but delivering 10‘S so I sent it back empty![]()
Rake was digbits £329 with sides, no pins and 50mm tines mateWhere from I’m after one currently
On kx71-3? Not your kx161?Rake was digbits £329 with sides, no pins and 50mm tines mate
I’ve had a riddle for 3 ton and 5 ton smooth 600 of them good buckets, gave me a price on a grading beam for 3/5 as wellGood guys at abiljo
