Mogmans creations 🤔
Is the trailer a homemade job or a proper thing? Ie something you’d sell me with knowing me... 😬
haha thought I’d ask, tbh I think my machine with a row of buckets would be abit tight on it.
looking forward to seeking the komatsu live again!
Had a few hours on it today (no tune though need to get some radiator hoses as the radiator also has a hydraulic oil cooler so can’t start it without the cooling pack plumbed in😩😩)
did turn it over on the key though👍still a bit of wiring to be done
its is a tight squeeze🤔 this engine is 50mm longer and 30mm higher doesn’t sound a lot but there is just no room
the pump is where it was originally but pushed to the near side a bit, and a bit higher😳
the ‘new’ bell housing is only just missing the oil tank (still got a bit of room for engine vibration 👍 though)
to be fair it sits in quite nicely, had to cut a bit of radiator cowling as the fan is a bit higher but cant lift the radiator as the bonnet will fowl it😩
see what tomorrow brings👍
Rob65
That looks like it’s supposed to be there.
With all that crazy talk of spending money and rebuilding the old engine you had us worried for a bit.
Thanks for taking the time to post about this.
Rob
T whiting
T whiting
It really does look made to measure Komatsu obviously weren't ambitious enough 😆.
Has it made the alternator /starter easier to access 😂😂
only took one picture today 😢 but been doing the fiddly jobs like sorting the wiring to the engine🤔 but all sorted now all the lights on the dash come on,
this ‘new’ engine had a hydraulic pump fitted the timing case that worked the conveyor so instead of removing it and having to make blanking plates🤔 decided to pipe it up so I’ve got two way service if I decide to put a rotating grab on it👍 but like anything on this machine had to weld a fitting from the tank outlet so the oil still goes through the strainer in the bottom of the tank and also a return that puts the oil back to tank but through the main return filter
now having a bigger engine is great😆 but no room under the bonnet for the air filter or exhaust😩 so have to think outside the box and engine bay
mock up of the exhaust🤔 will need to do something similar with the air cleaner too
View attachment 21690mock up of the exhaust🤔 will need to do something similar with the air cleaner too
At least then you’ll be able to dig really deep underwater too!
Rob65
Mog, Is it not likely to be a bit noisy with that exhaust right at the side of your ear?
