Lister powered Benfords would survive a nuclear holocaust.Me old benford manual with 3 cyl lister will be still be going after my days though.
I just soldMe old benford manual with 3 cyl lister will be still be going after my days though.
I had mine more than 10 years and started every single time i wanted itLister powered Benfords would survive a nuclear holocaust.
VINBest dumper I’ve ever owned though is a Mortimer sxd 060 6 tonner 4 cylinder air cooled Deutz noisy but brilliant . Used to be built by stohert and pitt
Hi Boyo ! I’m fine . Just catching up with the forum going through some threads , how you doing yourself ? How’s the fam did you see my post about the case hardened pins ? I reckoned you’d have the answer !!!VIN...... how the devil are you ?? .... long time no see
just responded Vin .... saw this one first ... how's life in the muir of ord ?Hi Boyo ! I’m fine . Just catching up with the forum going through some threads , how you doing yourself ? How’s the fam did you see my post about the case hardened pins ? I reckoned you’d have the answer !!!
Some have 2 return springs on the clutch pedal (mine used to) mine is lovely and light.I have a 2 tonne Terex 2006 swivel skip it’s a manual. It’s a brilliant little dumper with Kubota engine but the clutch is stiffer than a crash box on a scammell. The wife can’t even push it right down and she’s a powerful woman !
mid you have bad knees / legs then it would be a pain
Mine did have the 2 springs and I took one off and it made virtually no difference !Some have 2 return springs on the clutch pedal (mine used to) mine is lovely and light.
Feckin cold at the moment !just responded Vin .... saw this one first ... how's life in the muir of ord ?![]()
Its maybe a different clutch with the kubota (mines old lister) i know of one near me with kubota and clutch is horrible like you sayMine did have the 2 springs and I took one off and it made virtually no difference !
Worst thing is you need to push the clutch to the floor before the fecker will start !!Its maybe a different clutch with the kubota (mines old lister) i know of one near me with kubota and clutch is horrible like you say
Is it a big job to change ? I might get the missus doing a shift on it yetIf the clutch setup is what i'm used to it sounds like the carbon thrust bearing is badly worn.
That sounds about right , if you try to make a shift on the move you need to get the revs and timing bang on to get it in without crunching . Most of the time your crunching to get a gear . I just thought that’s how they were made !!Take gearbox out, in the clutch housing there is a weird graphite thing.... https://www.pesplant.co.uk/product/46890-carbon-thrust-bearing/ easy enough to replace if that is what it is.
Symptoms would be that you can push the clutch into the floor and it'll still grate. My (Was @Hg2702) Peljob is like this to the extent that the last wanker to hire it snapped the clutch linkage.... that's on the rebuild list next winter, will likely rebuild the box at the same time as it's cheap to do.
like me Zetor and that takes some getting down there ..... a modification is in orderWorst thing is you need to push the clutch to the floor before the fecker will start !!
They are just straight cut gears so you do need to match revs for changes to an extent.That sounds about right , if you try to make a shift on the move you need to get the revs and timing bang on to get it in without crunching . Most of the time your crunching to get a gear . I just thought that’s how they were made !!![]()
He said on the move i gather that means at speed (well above walking pace)Should'nt have to as such if clutch is working correctly unless your trying to shift whilst at speed.
