Buying a linear vibrating screen
N
NavaraGuy
I honestly don't know if this forum is the right place for this but I hope that some folks use here linear vibrating screen. We plan to screen topsoil removing debris, brick so we can reuse the soil at the site.
I rather think of some towable solution. Does anyone have something similar to sell? I see that some members use screening bucket but we just dont have the machinery for that.
Was a thread on here a while back, with a few homebrew contraptions including mine. A search might bring it up, I think it was within last six months.
@TiltyShaun , @JD450A could both comment with experience
Shaking Red.....aka Pinky Pie | Plant Talk - Plant Machinery & Construction Equipment Forum
maz
maz
Introduce yourself in the introductions section and let us know what machinery you do have, maybe folks can help 👍
Liner Screen is a horizontal deck screen that's flat and uses vibrations to move the material across the grid, not a lot of cop for soils which is why you see them in gravel plants more than anywhere.
A deck Screen is what you want... Larger the screen area the larger the throughput.... Won't work in wet material or Clays.
Someone is selling this on Facebook - can’t be too hard to make it mobile and run off a decent generator.
thinking about it somewhere I have a basic Vibrating screen. Would need a motor and mounting on a trailer or similar. I'll grab some pix.
Who had the harris fence panel job or was that CEF?!
Ollie Kitchin .. komatsu .... not been seen in months ... felt the need to 'distance' himself from social media ... apparently :rolleyes:
diggerjones
diggerjones
N
NavaraGuy
Thanks for the replies. Yes Ive seen these linear vibrating screens but as V8Druid mentioned the screening mesh sizing could be a problem. All used machines are purpose built and it is less likely that it suits our needs. I would prefer a towable screening machine as we currently dont have plant machinery to fit this onto.
Ive got a Nissan Navara. :)
I either build one as other recommend it or try to find someone who can build it.
I was reading this forum and I saw that others also ordered machinery from China. A screening machine can't be too complicated to build. I guess not many parts can be broken.
These folks "redstarscreening.com" offer custom made screening machines including a towable one. :)
I contacted them but they asked 5 other questions. :)
I smell a sneaky salesman :unsure: Abuse is about to follow I feel.
You've got a very simple out now before I loose respect and Ching Chong screening gets some abuse..... Like non forum abuse elsewhere.... Own up, or when @Regy53 confirms my suspicions I will amuse myself.
You know what really does irritate me.
Why pretend to be someone your not to try and bung up your companies website.... why not post pictures of the gear, it's manufacturing and put your product out there. That goes for all, not just the chinese..... Why Did H.E Services Sneaky Used machinery dealer play games among others.
CPS/Rototilt, Mr Engcon, etc etc have made a effort and have the respect from it :unsure: why not do the same...
N
NavaraGuy
Im not sure how I could possibly be a salesmen.
Ordering from China came from this topic: planttalk.co.uk/threads/cheap-chinese-wheel-loaders.1826/
Thanks for the input. I guess this is why I rather read forums and never comment.
I'll explain my workings. I thought the term "Linear vibrating screen" was a odd phrase to start with. I've never heard anyone use that term in the UK outside of very specific industrys. I've definitely never heard it used for a topsoil screener as, simply put they aren't designed or suitable for that type of work. :)
The Post with a single link to a chinese company I have never come across coupled with a huge amount of smiley faces fits the profile i've seen several times. :)
The last nail, is you want to screen topsoil but don't have the machinery to suit a riddle bucket..... unless your using wheelbarrows and shovels in Portsmouth it don't add up. :)
If you are using only shovels and wheelbarrows I recommend this fantastic bit of kit. https://www.toolstation.com/scheppa...mGuEd2V47-iUKhbOIZOw9QLqOLPPdndMaAsIFEALw_wcB My links work btw ;) :)
I don't think i'm wrong....
N
NavaraGuy
Thanks Sherlock. You never heard + smiles = forum spammer. I'll learn this equation. what a brilliant mind... Typical forum bullying. There is always an active member who has time to be smarter on forums as has the right to add spam to his signature. I guess this is my last post.
It's a bit more than that.
Some folks use her linear vibrating screen..... only one search topic comes up with those key words...
No digger? No front loader? How will you load the screener itself? that doesn't make sense either?
Your also following a pretty familiar pattern where toys get thrown out of the pram.... I'm actually annoyed because I could of wasted a hour of my time pulling a screen deck out of the back of the yard as a starting point for you to build one, so your getting the abuse you deserve.
