power generator problems olympian geh200 year 2001
L
leonsio212
hello
I hope you can help me.
I have a problem with high pressure oil pump on a motor.
I would like to know where to buy. Or maybe someone knows which one is right.(I need new one or refubrished)
here are pictures of pump and label of a motor if it helps.
And sorry for my english I am from Slovenia.
Common Rail High Pressure injector Pump off a International Engine, trouble is getting international parts in the UK will be a utter PITA let alone europe. It's a american thing.
obvious now you say it ... but was with Ross initially, as in WTF is that??? Wonder if Hyster use that engine in anything? Barlowworld were great for Hyster spares (y)
otherwise 'praps a couple of our contingent on here from across the pond could help ?
Charlie
Charlie
Quite a few cheaper that "LOOK" identical on fleabay e.g.
and
But I think he needs to speak to someone in the know as what is the difference between the two above? Navistar DT466 and a Navistar I530E / DT530 & HT530?????
Lota cash for a punt!
Adam
Adam
Bit late to the Party but that engine is also available badged as a Perkins 1300 series, i'm just looking to source two of these pumps and came across this post on google. This pump needs to raise the standard oil pressure to above 725psi under cranking conditions or the ECM wont fire the injectors.
