Some do, Some don't Graham.
The twin-hitch EC206-QS45 is about 150kgs heavier than the S40 equivalent. On 5-6 tonners this is noticeable and the 57-4 at Exac-1 in Upton on Severn is set up with the heavier option, whereas Fosseway Plant Hire run the lighter S40 twin hitch variant. The sole reason is that Exac-1 demonstrate a lot of hydraulic attachments and the EC-Oil system (both top and bottom) is a no-brainer.
I don't recall if Conrad and I went up to Exac-1, but we certainly discussed this in detail. If you are dropping the tilty off every hour then the QS45/EC-Oil is the way to go. If not, then S40 on this size of digger is a better option. Remember - S40 goes up to 6 tonnes, QS45 runs from 6 - 12 tonnes, so the Kub is right on the cusp.
It's always a case of 'informed consent' - pros and cons to both choices but in Conrad's case I think he was right to go for the lighter option. Hopefully, he does too, having run it for a while now
