Harford hydraulic tilting hitch
Hg2702
Hg2702
The 216 the rototilt is 70kgs the tilting hitch is 60kgs so should handle it fine
Been on footpaths In the Woods lately and you could literally get rid of 2 blokes and do it all yourself ... that’s the plan
Seems a lot of investment when you already got the tilting hitch. Smaller end of the tilties are fair bulky from what I've seen but you've likely got it worked out. Surprising the weight difference is so small tbh.
Hg2702
Hg2702
Fair bit of investment is need all around to be fair something we’ve thought and researched a lot looking to get myself set up for the future if we ever get to the point of upgrading the machine we can just transfer it over 👍🏽
So What are the other two blokes on the paths doing as it stands that the tilty would eliminate? One on a digger, one on a dumper?
I do loads of PROW paths on my own and admittedly being an anisociable bastard I do rather make hard work for myself jumping between digger and dumper all day long,the powertilt was ace for paths. Getting cambers right and doing the grips but couldn’t really see how much extra advantages full tilt rotator would be?
Hg2702
Hg2702
Good question ...
It’s not just labour it would do away with its things like buying a grab you technically save yourself the money of the rotator on that (£1500). The ability to work at 90 degrees to yourself in situations where you’d normally struggle with access
personally I’ve been trying to convince myself for a while now and having used one I can see where it would improve efficiency. Might be a load of bollocks and be for sale in 6 months time but personally think it’s worth a try
I would want a rototilt on the biggest machine I could move myself and keep the powertilt on the 1.5t but everyones work varies of course (y)
If you go tilt and rotate there is no way back!!! I am happy in either of the two T&R diggers. But the tilt only is just not the same!!!
Hg2702
Hg2702
since driving one its not been the same 🤣 your constantly thinking I could do that quicker
Good question ...
Nothing ventured nothing gained. Sounds like you’ve done your homework on it so sure it will work out well for you.
The Tilt Rotator argument is always a interesting one.
Key question is will it earn you money..... and in the words of Taylor.... "Really, Realllly?" It's easy to justify toys you want, I can justify the motor scraper on the premise that I can strip topsoil with it, or the Pel Job on the basis that it was cheap enough to sit around (needs to do 10 weeks Hire to pay for it'self).
You need to get into the nitty with a tilty to actually add it up. Ultimately if it makes you smile why not get one, but IMHO you
Like I say if not look out for a cheap tilt rotator in 6 months time 🤣🤣🤣
I'll start saving ❤️
Hg2702
Hg2702
Like I said the grab which I’ve work for it’ll save me buying a rotator say £1500 quid saved and you’ve all but got the difference between the tilting and the full set up ... I’d rather try and fail then sit back plod on and wonder what if however I would need a bigger yard for a scraper 🤣
I don't think you'll regret it Harry on any machine you put one on. I've said it before, but tiltrotators don't just pay for themselves directly by speeding up a task. It can win you more work with new customers who like your progressive thinking. It can also take a man off the ground in many situations. And wages don't take long to add up.
Everyone's work is different and there will always be a bit of unknown when thinking about buying one. Do your research, and if it adds up, then go for it - you wont regret it.
Good question ...
put a 4 way pick up on your bucket and continue with your tilt hitch ?? ?
I think when someones got their mind set on something its difficult to compromise .... I know I struggle :)
