Tool of the week
Not needed them for a longtime, but a toolbox essential, a very nice BT man gave me a full box once, always had some in the cab ever since 👍🏼
FYI - they are gel filled phone line connectors, justshove wire in and press together
Those are brilliant - I have some from a similar source (never been able to find them for sale though).
You can also reuse them if you squeeze the sides with pliers - they pop back open.
I use glue heat shrink connectors.
Will be interested in how it fares long term. I kept looking at those as they are damn cheap, but botteld out and went with another R-tech for my smaller mig I bought last year.
ditto ... 'tis bloody cheap ...... but 8.2Kva input :oops::oops: .... no wonder they include a 32A plug and socket .... and that's pushing it !!.... my 250A Warrior is on an adequate 16A plug :unsure:
It's not as bad as it looks - the £0.39 is for a 5 pack, and a 50 pack is under £2
Charlie
Charlie
They are great and I go through 1000's a year for connecting firework wiring. The proper pliers do help with reliability although they can be done with any pinching tool or your teeth. Don't put a handful in your pocket on a really hot day as all the gel runs out lol
Russell
I wouldn't pay too much attention to the 200amp rating, will no doubt be Chinese amps. I had it almost flat out with 0.8 wire and have only blown one 13amp fuse trying to weld a tow bar on the dumper. It's good for thin stuff but I wouldn't buy one for thick steel. Luckily I bought it to weld up the rangie and that it did well.
Come on mate, don't be shy. Show us some photos of the the actual welding... :ROFLMAO:
neat idea Russ
If you post pics we can give you tips on how to improve....
aaaaaaaan' take the piss :ROFLMAO::ROFLMAO: ............ not that I would ;):giggle: ........................... but there are those that would :unsure::sneaky::whistle: .......... mercilessly 😂😂😂😂
Russell
I think it would look better if I did continuous welds to get it hotter. Trouble with that is it would pop the 13a fuse. I need to put a proper cable to the shed rather than a extension lead.
G
Grifferr
So i wanted a easy way to check the weight of some buckets and kit that goes on my trailer. Looked on ebay for crane scales thinking something secondhand. Then i noticed this and seamed ideal upto 300kg. So £17 was sent and see what turns up. I will say i am quite pleased with it. I tested it on a bag of cement to start thinking it was not going to be very accurate but 25.1kg including a strap around the bag
It just seams to be a nice cheap and easy way to keep an eye on the weight of things.
I have exacly the same thing, bought five years ago for the same purpose. Really handy.
T whiting
T whiting
You've got to get one of the black rubber plugs the white plastic ones just leave the pins in the socket 😉
Tbh it's not hard to wire in a 16a plug if it's just for use in the workshop
