bobthebuilder
Hired in a 1.5 taki a while back to rip up a floor ,300 for a week
absolutely .... 300 quid in your pocket, not someone else's .... 's why I buy not hireYeah cheap enough but might aswell use my own gear.
I haven't used this in anger yet!View attachment 17410
I know i would rather buy but thats the first time to do that to a floor ,have a tb125 with a hammer but a bit big in this instance,
that Kub morphed into a C@T overnightView attachment 17417View attachment 17418View attachment 17419
Soon gets tight inside a building with a 1.5![]()
Kub went in first for a week then cat did the rest at a later date.. was 400mm of concrete in places, no bother for either machine to be fair.that Kub morphed into a C@T overnight![]()
Is that the breaker i bought off you dave.Kub went in first for a week then cat did the rest at a later date.. was 400mm of concrete in places, no bother for either machine to be fair.
Yes mate, hope it’s going strong stillIs that the breaker i bought off you dave.
Yeah used it a fair bit. Never had 1 before and never really needed 1. But since i bought your its been invaluable. Wants a new pin.Yes mate, hope it’s going strong still![]()
Surprising isn’t it, I kept my big breaker Off my 3cx for the 6t Don’t use it much but when you do it soon gets through the concrete!Yeah used it a fair bit. Never had 1 before and never really needed 1. But since i bought your its been invaluable. Wants a new pin.
I want to but I haven’t got the balls to do that. Minimum 400kg over surely.This was a first aswell. Digger on truck.View attachment 17741View attachment 17742
I had thought about it before. The job i was finishing was up on a high patio and the next job i had to get on top of a high bank so thought i would give it a go. The Kubota would be the best especially with the cab off.I want to but I haven’t got the balls to do that. Minimum 400kg over surely.
Was clearly on private landI had thought about it before. The job i was finishing was up on a high patio and the next job i had to get on top of a high bank so thought i would give it a go. The Kubota would be the best especially with the cab off.
The Kubota would only be less than 1400kgs.
The case would be over 1600kgs.
Cabstar legally carries 1400kgs ☹
So over weight about 2 or 300kgs
Carries it no problem.
My biggest fear was driving it off the side. Being a tipper there isn't anything holding down the body at the front. I strapped it down and it worked well.
If the pivot point for the tip is not on the very a*s of the truck would you be able to tip truck part way so the ramps aren't quite so steep & fabricate something to stop it tipping further while loading?I had thought about it before. The job i was finishing was up on a high patio and the next job i had to get on top of a high bank so thought i would give it a go. The Kubota would be the best especially with the cab off.
looks quite sensible on there Dylan ... truck looks happy enoughThis was a first aswell. Digger on truck.View attachment 17741View attachment 17742
would it fit on one of those castor trolley bases the supermarkets get their deliveries on ? ... or extend one with some ply? Got a couple here ... one on top of this, upside downEasy enough. About an hr. Moving it about on the floor is a pain. Heavy little bugger
