Why do you need a linkage? Surely a man of your capability can build something cultivatoresque that you can just drag around on some chains.
Or if you are taking the skip off then make something ground-engaging that mounts to the skip hinge-points and can be lifted off the ground (to allow for turning and dropping built-up roots/tyres/corpses/asbestos out from underneath) by using the tipping ram?
Get on with it, stop fannying around and make something ace!!!
