Wanted 3 point linkage
Why do you need a linkage? Surely a man of your capability can build something cultivatoresque that you can just drag around on some chains.
Or if you are taking the skip off then make something ground-engaging that mounts to the skip hinge-points and can be lifted off the ground (to allow for turning and dropping built-up roots/tyres/corpses/asbestos out from underneath) by using the tipping ram?
Get on with it, stop fannying around and make something ace!!!
Yes to the above👆👍👍
as you know I take a week build Something that will save me a day🤔😂😂
Cultivation equipment has to lift in parallel and need the arms to float on balls at each end if it raises in an arc you can't adjust how aggressive it is working which on the first pass of something rough will be a constant adjustment
And it needs to be able to sway lift and oscillate in all directions or something will get damaged
Most simple plan is a draw bar on it and just tow it round in circles disks don't really need to be lifted at headlands
It’ll only need ‘full aggression’ I’d imagine. Some ‘implied‘ dumper load on a couple of toothed grading/levelling beams joined together with a world of heavy steel, bits of chain, a couple of boat anchors etc. It’ll be ready for grass seed in no time!!!
(When it breaks just weld more steel on I believe is the normal form chez-Mog)!
I get what you're saying about the ground but a tractor will grip far better than dumper and pull a lot better as a dumper drivetrain is very power hungry. If you're that worried about tyres on a tractor getting torn off sounds like you'd be better off with a drot or dozer.
I know It will.need alot of aggression but at the same time the more aggressive it is the harder it is to pull and disks tend to snatch into the ground if you whack it in to aggressive to begin with
Mogs dumper is a wee bit different 😂
Cheers mate but I’m a tight git and looks a bit over priced to me🤔
you tight git :p:ROFLMAO: .. is that far from you Dylan ?? don't think that's over-dear TBH ....
diggerjones
diggerjones
Not realy. About an hr. I passed twice this week on my trip to snowdonia. Its where they make ivor Williams trailers.
Be surprised what you can make for £400 as long as the material comes from ‘my’ scrap yard😉
probably not Mog ..... 'specially when yer labour's free ..... just need the yard to source bits :sick::sick:
