Local sale
diggerjones
diggerjones
diggerjones
diggerjones
Monthly implement sale tomorrow at market Drayton
diggerjones
diggerjones
It caught my eye because i remember them and the discussion on here. The top part looked like it still had galv on it. Were they galvanised originally
diggerjones
diggerjones
The jcb buckets i showed pictures of. The v ditch and clay bucket are there aswell.
Whats the bid on the salamander. Not sure if I'm going but can sort it
I’d chuck £30 at it
I will let Moggy go for it if he wants.
diggerjones
diggerjones
A question was raised about their continued availability, or a modern equivalent. They've probably gone the way of many old but potentially dangerous pieces of equipment on the altar of 'Elf & Safety.
I once worked for Whitlock Bros., who then made hydraulic excavators in Great Yeldham, Essex, the assembly being in buildings designed as aircraft hangers with full height doors that ensured a complete air change in seconds every time they were opened, several times an hour. So radiant heating was provided in the form of Salamanders that burned any sort of waste oil, and we had plenty!
For those who are unfamiliar with these heaters, they were rusty sheet-metal devices about 6-feet tall, with a chimney standing above the waste-oil tank and a "Chinese hat" above the chimney to keep out the rain. A re-circulation pipe from the top of the chimney back down to the oil tank played a flame over the surface of the oil to vaporise it, and in use the whole thing roared like a jet-engine, with the chimney being a near-incandescent bright orange, radiating heat, well....several feet. On the chimney was an enamelled label with a list of things NEVER to be done; DON'T refuel while hot, DON'T relight until thoroughly cold, DON'T move while alight, DON'T ......
One day a foreman came into my office, totally black from head to toe except for two white eyes and a smile. I asked what had happened he replied "I did!"
An inspection of the accident site revealed the Salamander standing at "Ground Zero" surrounded by a circular area of deposited soot, except for a clean sector where the foreman had been standing to collect his share.
Apparently the heater had run out of fuel, so he'd refuelled it while hot and then re-lit it by dropping a lighted rag down the chimney. The consequential explosion cleared the chimney of its years of accumulated soot, which first was blasted upwards until hitting the Chinese hat that deflected it radially outwards.
My regret was at not having seen it happen.
great heaters, but need a good supply of waste oil ...... I believe they're still available ... and yes galv from new
