Wacker - what oil in the vibrator
Routy56
Routy56
As the title suggests - what oil do we put in the vibrator unit please ๐Ÿ˜‰
This HS60 with a nice Lifan engine for 5 or 6 years for occasional stuff ๐Ÿค
on the last few outings it leaks oil from the end seal of the vibe unit ๐Ÿ˜ฑ
Gonna need to simply top it up for tomorrowโ€™s job. Then it will be a bit of workshop time ๐Ÿ˜‰
The question is what oil should be used. Nothing in the manual ๐Ÿ˜ณ
Routy56
Routy56
Bounce ๐Ÿ˜‰
Supposed I walked into the suggestion by @Quattromike ๐Ÿ˜‚
May be using this very soon so any sensible suggestions pretty please ๐Ÿ™๐Ÿป
Bounce ๐Ÿ˜‰
If all else fails any oil is better than no oil. Its only bearings to oil in there anyway i would think (never needed to take one apart to find out what's inside) it'll probably just be engine oil.
AFAIK there is just two bearings and an offset weight in there so any oil better than none, light grease should also do the trick
Left hooker
Left hooker
Engine oil is thinner than gear oil so would use engine oil
Another of those threads that makes you think, so according to handbook my little petrol wacker uses ATF in there.
So my little petrol wacker says ATF yet big diesel uses same engine oil as the engine 10w 40. So as its only splash lube for bearings use whatever you got out of those two and it'll be fine. Just as long as there's oil in there be ๐Ÿ‘Œ
Left hooker
Left hooker
Atf is thinner than engine oil so would create less drag for off center weight but lube bearings
Steve
As said above thicker oil will cause more drag, thinner oil will piss out the end seal.
Presume the bearing is running rough to have knackered the seal.
Routy56
Routy56
Thanks guys for your suggestions ๐Ÿ˜Š
Will stick some engine oil in rather that the SAE 95/140 that I have in the cupboard ๐Ÿ˜‚
Bearings seem ok. So perhaps if Iโ€™m motivated Iโ€™ll pull the seal and replace it ๐Ÿ˜‰
Bob
Bob
had to change my wacker plate bearing and seal in april I have found if seal is leaking bearing is often on its way out
I got 1 seal and bearing from simply bearings total cost ยฃ15.06 easly to fit
Steve
I find it's usually seal gone because bearing has started to fail.
Routy56
Routy56
That @Bob and @Steve for the above advice (y)
Workshop time will need to be factored into the next week then :ROFLMAO:
BTW - what grade of oil to you stuff in the hole :unsure:
Why not just replace with sealed for life bearings, chuck a seal in for good measure and fill with oil for belt and braces ;):giggle:
Steve
I did a gearbox last year & the bearing supplier only had sealed bearings, they advised this but suggested I tore out the inner bearing seal to allow the oil in.
why ?? ... they're sealed for life
