Good on you Gus. Make sure you are charging enough for your time though pal.2606 miles in 15 days... and 2 of those days it didn’t move. Gotta go where the work is lads.
Bloody hell Gus, you don’t half get about!
'xactly my thoughtswhat he said
I think your new van will be well and truly run in.
me tooI was thinking the same.
Was that at Jenkins tip with the d62606 miles in 15 days... and 2 of those days it didn’t move. Gotta go where the work is lads.
Cat D6N LGP in Exeter converted from System 1 to SALT chains and running equipment.
Sprocket segments replaced
Idlers replaced
All Top and bottom rollers replaced
Not being shy put it that way lolGood on you Gus. Make sure you are charging enough for your time though pal.
They are actually plenty of meat on them, someone has decided to weld flat bat in between the grousers to create almost a flat pad
Yes that was there tip of trood LaneWas that at Jenkins tip with the d6
It’s a replacement chain, when fitting the original I wasn’t happy with one of the connections on the crock link so arranged a replacement chainwhy did you have to remove the pads from already built up track groups gus? Did who ever built them not remove the paint from pads and chains?
A lot of working to be doing just for a crock linkIt’s a replacement chain, when fitting the original I wasn’t happy with one of the connections on the crock link so arranged a replacement chain
To be honest it didn’t take long, only 2 hours to strip, swap chain and clean &refit pads.A lot of working to be doing just for a crock linka would have burnt the fucker off and put a new one on that way
That’s only about 5 minutes from meYes that was there tip of trood Lane
Nice part of the country, was hoping to stay overnight but didn’t get a chanceThat’s only about 5 minutes from me![]()
hell of a blade on that WNCouple of repairs on a rototilt R3 and Rototilt R5.
I really like these wacker Neuson machines. They seem well built and laid out.
Hear lots of good things about wacker Newson..... will have to check them outCouple of repairs on a rototilt R3 and Rototilt R5.
it’s All true.Hear lots of good things about wacker Newson..... will have to check them out![]()
