Wanted - Track Barrow
After a Tracked Dumper. Preferably a Hinowa around the 600kg - 1t mark. Condition not overly important, engine doesn't need to run but does need a reasonable U/C and Final Drives. MUST Be Hydraulic Drive.
Budget of £2000 for what I want. (y) Money waiting, Bank or Notes.
Neilporteous
Neilporteous
I have a Tcp ht500 that would maybe tempt you, good runner, good hydraulics, new tracks
Rob65
Rory, Is this to be used as a barrow or is it going to be used to carry an “Invention’?
I have a HTD5 that I converted to 110v drive that carry’s a small drill rig. Great little machine.
Rob
Rob
As a barrow, but not without some modification. Notably a rear Wheelie bar and a winch point on the front.
Had one agreed with a non running engine at £700 yesterday plus pallet which I was happy with but alas the man has changed his mind overnight :( which is somewhat disappointing and more so if It was down to money :/ as the £700 was his happy figure and i'd of quite happily gone a bit higher as it was a Hinowa 800 which is what I would ideally like....
I've another Hinowa in mind but it's quite abit bigger and I expect somewhat over the current budget... but we will see :unsure:
what happened to the rail system ?? :unsure:
James ..... where's me coat ?? :unsure:
thought you had a rental all lined up :ROFLMAO::ROFLMAO:
Railway and winch is ordered.
Got the gear lined up to cut the track in, issue is two fold. I need to Ballast the Line before the sleepers go down (once installed the final ballasting can be done via the carriage)
Secondly once the track is in, it'd be handy to have a track barrow at the top of site anyway.
I have a fallback I can hire, but for obvious reasons i'd rather buy one.
If Rory don't want it I'll take it off you no probs
Ste
I've a couple of people who I need to talk to today R.E hinowas. But I will likely have the TCP. Tip angle should be spot on for the job and it's on proper final drives. I'll have a chat with you @Neilporteous if you send me your number over.
Neilporteous
Neilporteous
I will put some pictures up today.
Its worth noting that there is some wear on the track rollers and the drive sprockets, all still works fine however, I was going to replace the drive sprockets and got a quote through from TCP, they are coming in at £300 for the pair inc vat, the dumper can be sold at £2200 without these being replaced or I can replace them and the price would be £2500 to cover, also the price is plus vat.
Still a Cheap machine (y)
any folding figure in mind ;):rolleyes: .. 20%'s a big slice :cry: PM me??
