Terex hd1000
Stu moxy
Hi, had the forward/reverse cable snap on the dumper, I’ve replaced it but struggling to get correct adjustment. It either wants to creep forward and reverse buzzer stays on most of the time. Any help appreciated 👍👍
welcome Boyo ..... some more details on what it is exactly would help folks with suggestions .. make/model/size/etc ??
jd6820
jd6820
I think something is a miss then? Start with the hand control lever in neutral and set the cable position based on that. Just be aware the cable can jump out of the hole on the lever pivot if that makes sense? Once attached at the lever move down to the drive pump, the bracket near the lever (attached to drive pump) is to allow adjustment for neutral position. If you don't have enough travel or correct travel adjust back at the lever. The nut positions on the original cable will give you a good start point. Strange it should have snapped they are a tough cable, are you sure this hasn't broken something else???
Damaged outer cable and then rusted would be my guess as to why it failed (had it in roller). As said above for initial adjustment. Reverse beeper will more than likely be triggered by a micro switch on the forward reverse lever. It might just be stuck.
sorry ..... just noticed the title of the thread :unsure::censored::censored::censored: ... been a long day
