Welding Acid-proof stainless steel ?
Bucket on wheels
Bucket on wheels
I've been asked to make a generator frame to sit below deck in this Viking ship they want it made out of Acid-proof stainless steel 70X70 mm angle with 7 mm thickness
what kind of welder would be be the best for this job ?
tig, mig, mma.
I'm most comfortable using the two First once.
They will supplie the equipment and ask what I prefer to use.
Flux cored stainless MIG, make sure it's 316LP wire as no doubt there will be positional welding. If you have the option get a welder that has the cr-ni program and use weldapp2 gas. Welds a dream and quick πŸ™‚
At the risk of proving my ignorence (I've only welded stainless with stick), do you need a shield gas with a flux cored wire?
Yep , Will probably be Β£350/Β£400 for the roll of wire but the time saving and look of the job will more than pay for it IMHO
box of rods'd be the cheapest option :rolleyes:
If the welding is being done in situ they might have some swimming to do
