How many attachments have you got🤔 not counting your buckets, what are they and what is there intended use,
not that many Oh Great Att Collector of Northwich :p:LOL: .....
Cranab grapple, you've all seen how much use that got,
Kinshoffer 500mm clamshell, again well used on stoning up drains, etc,
Steinweg block grab, has moved a few packs of blocks about ... was a gift at 100 quid and has contributed SEC
grapple, Bomford flail, forks for under the VA-r, forks for the main 70mm hitch
Um. Mid post and I have been locked out by some upgrade to the forum
Been FB msginf Ross but no luck yet
On me fone on WiFi but its too much faff &too small
Will see you all when I see you
Don't know how the f*** I'm going to resolve this one
T whiting
T whiting
I don't think I've seen the Bromford flail does the Hydrema have enough oil flow to run it? It's something I'm considering adding for cutting the couple of hundred meters on the farm and the banks of the lagoon
Regy53
Regy53
I like cake
Latest 2020 ssl's have changed so most sites will move to them them but it may render windows XP browsers defunked sadly.
a matter of when and if not if across the network.
Cyberprog
Cyberprog
it seems to be my steam powered old girl sadly
I can send you a recommendation for something a bit newer if you have any budget for it? Just need a new tower unless your keyboard/mouse are ps/2 (round barrel, not usb)
just want to say a big thank you to Ross .... he's pulled out the stops to get me back here for a little while ... updating me 'puter may not be so easy ATM ... I got another 6 weeks locked up yet ... middle of june, 'fore I'm allowed out ..... Might have to buy a cheapo lap top on line for now :unsure:
Cyberprog
Cyberprog
I can whip something up here for you possibly. Won't be amazing, or can find you a deal on eBay?
You will be so disappointed in a cheapie
I bought one as very very rarely use a computer and definitely not for anything strenuous and it's terrible
Wasn't the cheapest but definitely budget and it was the biggest waste of money possible
As a stop gap have you considered a tablet
They can more than match the power of cheap laptops
Can use it anywhere so can take drawings outside with you
Built in camera so upload straight to the forum
Then get a proper computer when lockdown is over
Did it think you were a spammer?
dunno ..... this kept coming up when I tried to get back in
" This site can’t provide a secure connection
www.planttalk.co.uk uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
The client and server don't support a common SSL protocol version or cipher suite. This is likely to be caused when the server needs RC4, which is no longer considered secure. "
have since found this on't net .....
"This webpage is not available" or "ERR_SSL_VERSION_OR_CIPHER_MISMATCH"
You'll see this error if you try to go to a website with an outdated security code. Chrome protects your privacy by not letting you connect to these sites.
If you own this website, try to set your server to use TLS 1.2 and TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, instead of RC4. RC4 is no longer considered secure. If you can't turn off RC4, make sure that other non-RC4 ciphers are turned on."
mouse is USB keyboard is old skool roundy ...... my wireless KB died a few months ago so plugged this one back in
Cyberprog
Cyberprog
https://www.ebay.co.uk/itm/333555774215 would be a suggestion, £75 with 4gb ram and a 320gb disk.
I'd recommend 8gb ram at least 16 if you can afford it, and a SSD also. Should work with your existing screen on VGA or you can hook to a TV on the HDMI. Nice tiny box of tricks too.
