Which machine does this bucket fit?
L
Lewisb
Hi
Wondering if someone can help me.
Just bought a trenching bucket for my 2011 1.5t kubota Kx-36. Its turned up and the pin holes are way too small. Did they change the pin hole sizes over the years at somepoint?
No good to me so want to sell it but not sure what it fits. Wondered if someone would be identify using the dimensions below.
Pin diameter - 25mm
Distance between hitch holes (centres) - 90mm
Dipper width - 100mm
thanks in advance!
JCB 801 although my notes say 95mm dipper width for the 801.
Exact same for a KX36 and KX41 Kubota.
What pin dimensions have you got on your machine?
I thought the kx41 was 30mm pins. But the kx36 was 25mm.
I have a brand new kx41 bucket (about 10/11 years old now) but was 30mm pins
diggerjones
diggerjones
My kx 36 is 25mm pins and 95mm width mine is old 2003
Not certain, I'm not very familiar with the smaller kubota's. I have a list of pin sizes, it has kx41 as 25mm, but not sure if they changed with dash 2 to 3 etc
Thats a good point. I know that bucket i have is the 41 dash3
L
Lewisb
So measured my pin diameter and bucket holes and its 30mm?? Googled it and it says the kx36-3 and 2 has 25mm pins. Im confused!
Have you had the machine from new? Could be a case that someone replaced the bushes with 30mm..... especially if they had to bore the boom because it was worn.
Sloany
Sloany
There you go👍
mart1602
if its around the time of a model change could of used up parts from 2 runs old and new ,most factories would do that sort of thing
