Tilt attachment for buckets??
You will pay a fair bit more but I would save up and go with a Helac type - they are bullet proof and much smaller, will fit down a trench - and tilt 90°
I was very tempted to go for one of these when I first had my Kubota Kx71-3. I kept holding off and after trying a proper tilt and rotate Engcon unit that won the day!!
Helac or RSL ?
I was tempted by the RSL unit but was concerned about the width and build height.
Alright guys, iv been looking into a tilting grading bucket from Lemac (anyone have any experience with them)?
Iv come across the tilting attachment that is universal and would work with all of my buckets https://www.ebay.co.uk/itm/excavato...362122?hash=item2a47bf8c8a:g:higAAOSwaNBUcJb-
Whats the thoughts on these things? does anyone have one and what are they like?
I have a Lemac tilting bucket, hell of a well built thing, and that’s also it’s problem, it’s so incredibly heavy! That might not be the case on a smaller bucket, but if I was looking at buying one then I’d certainly check the weight of the buckets when comparing, as overall weight is a big consideration on any machine, let alone a small one.
Exac-1 I've always found to be bloody expensive. I'd recommend Harford, especially as the coupler on their tilt hitch is the excellent wedge-type Pro Lock- your buckets are always tight.
I think I recall a price of around £3200 for a Harford powertilt.
there's also these little units, but have restricted tilt ... IIRC 30 degs
Steelwrist were marketing them under their own banner ..... don't know if they still are ... American design/maker ... can't recall their name ... Ollie might - @Komatsu
I would look at the weight of a tilt bucket too ... I have a Geith single ram on the 8t and its a hell of a lump on the end.
Dont know how a tilt ditcher adds up weight wise compared to powertilt and standard ditcher :unsure:
wee_gus
wee_gus
Neil, go down to Badenheath industrial estate in Throsk, it’s where H&R Gray haulage are, look for MIM, and speak to Scott, he should have what you need or he can make one for you, that’s who I use for all my buckets and wear parts
Neilporteous
Neilporteous
Cheers Gus, I will pop in and see him, il let you know how I get on.
Hg2702
Hg2702
Give Harford a call I’ve had one and will be adding a second ! Maybe one day 🤣 can’t recommend them highly enough
Hg2702
Hg2702
I’ve got some more pictures when I get 5 minutes
Russell
Do you loose anything fitting one of them? Like power or dump height? Would it be a bad idea on a micro?
Hg2702
Hg2702
I’ve gained extra reach and to be honest I haven’t noticed any loss in power the pros of the tilt far outways any loss in my books as it’s suited for my sort of work
And that is the nail being hit by the hammer....suited for the work you do!!!
My 8 ton Kobelco is used mainly on big bulk work where the Engcon would be no benefit. On the 3 toner it has never been taken off!!
