is this as big as it looks? !!!!
bloody cheap if it is
I think it’s a trick of the camera and it’s actually pretty small - it looks to be on top of a container of some sort pretty close to the camera. Imagine the steel ribs it’s sat on are a container roof sideways and the perspective changes a bit.
Bucket on wheels
Bucket on wheels
I do not no the standard manhole sizes in UK. But here in Norway we have this sizes I would think it covers everything from 650 to 2000
K
Komatsu
Yeh there’re multi pick-up Frank, and as long as there set up right there’re great bits of kit, unfortunately, more often than nkt there not set up right, and get put in a the corner out of the way, then collected at the end of the job🤔
From their website 625-1500mm rings with a 2.5t working limit around 2.3k plus vat new
now you say it I can see it's a container roof ... just didn't click when I first looked at it and thought ... jeeeez tha's a big beast
tinydigger
tinydigger
biggest problem apart from them not being set up correctly as komatsu said is where the dust gets stuck in the grips and then wet sets like concrete and means they wont grip at all. Normally couple of minutes with a wire brush and a cold chisel cleans them out. We have about 3 in our yard out on hire and a customer ho has about 5 they own that we service
tinydigger
tinydigger
It looks a bit of a beast!! What exactly is it used for???
one man lifting manhole rings hang it from a drop chain off the machine and lower it in to the ring when the 3 upper arms touch the top you wiggle it and start to lift it the sliding cam the chain and shackle are attached to move over and up pulling the lower arms in to the inside of the ring clamping it and lifting to release it is just the opposite. made by probst
Surely it would be better without a droplink so a rotator can be attached otherwise you still need a rigger to straighten the steps up
What happened to the holes in the side that you put rebar in to lift them with chai s on your digger!!! Crazy world we live in now!!
Can still get lifting pins for them I got sent to pick a set up the other day
I've got big shackles that fit until you get to bigger rings with 4" wall
tinydigger
tinydigger
The gangs i normally see on site using them line them up when they off load them so the steps all sit the same way so when they pick them up they are all in the same plane for placing
they are still there a lot of customers still use the manhole pins for shallow rings a lot of deep drainage boys use these as saves sending a man down the hole also seeing a lot with cast in nuts that you can get a threaded wire lifting loop for
I just use a set of lifting pins and chains. I’ve never seen one of these contraptions for lifting them. My initial concern with using that thing would be the forces exerted on the walls, one hairline crack could quickly develop into disaster.
tinydigger
tinydigger
most of the ones i deal with are for bateman ground works shovelhands for there deep drainage gangs although have had a couple out with some builders merchants when they got a lot to move in there yard
