Haven't seen it first hand but can't see it being something you want to use much.What about the Rotatilt 'pulse' function?
Thing is for a riddle bucket to work effectively it needs more movement than just a vibration. It's why I'm looking at a proper screening bucket. Not something i have loads of use for and maybe an expensive solution but I've got another 25/30 years to put in so it'll pay for itself.Haven't seen it first hand but can't see it being something you want to use much.
I see your ladder and raise you a wacker plate! This was screening a couple of tons of coal out.Got a slate waste path. Its been down 15 years contaminated with soil. This was the best i could come up with. It worked really well View attachment 13792
Probably the worst use for one tbh you end up rattling lumps of conc about in the bucket. To get lumps out of small quantities of topsoil if dry there ok as a cheap solution. Best use i have for mine is sorting walling stone but i don't riddle it. Fill dumper with water and dunk it to wash it. When i bought mine i had it made to fit 4 and 8 tonner and have since changed 8 tonner and need to adapt it to fit. 18 months and i haven't bothered.....So I reckon that's a 60/40 split of 'yeah they're great if dry' and 'no, they'll f**k the machine'
Furniss says 'used sparingly'. This was my thought too. Won't take long to pay for itself sorting concrete from muckway.
Any consensus on which pins are at most at risk of wear?
I think you have made the best solution. Why bother with a riddle bucket. You winI see your ladder and raise you a wacker plate! This was screening a couple of tons of coal out.View attachment 13793
Setup is a pain.I think you have made the best solution. Why bother with a riddle bucket. You win
it was Dick Searle - - Red Rhino he called himself ... Essex way IIRC .... got a couple of drums here to knock one out with .... when I get inspired ........ can't find him on ebay this morning ... Might be Lord Tim Searle's brother IIRCHow about making a rotary one out of a cement mixer? No wear on the machine so likely to get more use out of it. I think there was a guy selling them on ebay and there was a thread on the old forum. All I could find was a picture.
There is a firm making vibrate units.... Can't find the details as I'm on the phone but put it this way, I am tempted.What about the Rotatilt 'pulse' function?
Small Volume AC110V Vibration Motor To Make Concrete Counter Tops / Sieve Screen | eBay
Find many great new & used options and get the best deals for Small Volume AC110V Vibration Motor To Make Concrete Counter Tops / Sieve Screen at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
Vibrating Motor Vibration Motor 30/40W 110V 220V 380V Miniature Vibrating Screen | eBay UK
HY-0.4 220V/110V 0.19A/0.38A 40W 25 2940 3450 2. HY-0.4a 380V/220V 0.140A/0.107A 40W 25 2940 3450 3. Speed: constant speed motor. Low noise, high efficiency, long life, adjustable eccentric block. Function type: drive motor.www.ebay.co.uk
Now you mention, it I remember seeing it listed .. was a grand IIRC .... pretty sure him and Tim are related ... Tim is a really nice bloke ... helped him out with some spec.s on a crane he had a while ago and he still calls for a chat occasionally ... Tim is jojorae2000 on ebay and gets some pretty way out stuff and usually has pages of stuff ... pretty limited selection today ....Don't think Dick makes them any more. He was the guy I bought my Powertilt from.
I do a lot of screening with rotary screening buckets. I also have a star screen bucket with poly stars. What do you want to know?I have one for 8 tonner when stuffs dry it's ok but don't really like using it tbh shakes digger to bits. I'm actually looking to buy a screening bucket to suit 8 tonner if anyone has any experience of one.
Might have been you posted it on the old forum... if so then thanks!!Now you mention, it I remember seeing it listed .. was a grand IIRC .... pretty sure him and Tim are related ... Tim is a really nice bloke ... helped him out with some spec.s on a crane he had a while ago and he still calls for a chat occasionally ... Tim is jojorae2000 on ebay and gets some pretty way out stuff and usually has pages of stuff ... pretty limited selection today ....
Im looking at one for screening topsoil which is often damp had been looking at one of the poly star buckets. I know remu do smaller buckets but they are v expensive so I've ruled those out. It's not to do vast amounts what make is ur star screener bucket?I do a lot of screening with rotary screening buckets. I also have a star screen bucket with poly stars. What do you want to know?
For rotary screens, to state the obvious, the bigger the holes and the dryer the material the better they work. You really need roller brushes to keep the screen open, but they tend to wear reasonably quickly. They only work well if most of the material is the undersize. If you are trying to get a small amount of undersize out of a bucket of oversize it is difficult to stop the larger bits blinding the holes and stopping the undersize getting out. Buy as big as you can pick up as you only really want to half fill the bucket otherwise there is little material movement and it takes for ever.
Poly star screens, all of the above, apart from finger cleaners rather than brushes, but they will cope with damper conditions. They separate by size, but if stuff is coated with crap it won't take it off, ie, it won't clean up dirty stone, just separate it. They are faster than rotary, but more expensive and you are stuck with one size screening. Also I have had much more problems with bits breaking on star screens.
